Here's a nice doc from the FAA regarding sunglasses:
http://www.faa.gov/pilots/safety/pilots ... lasses.pdf
Sunglasses
Re: Sunglasses
Stopped by the local airport pilot shop. They only sell and recommend three brands, AO, Ray-Ban and Randolph Engineering.
They seem to feel that all of them make great lenses, that AO is a less expensive version of Ray-Ban and that Randolph is a sturdier version of Ray-Ban.
Anybody using Randolph Engineering sunglasses?
http://www.randolphusa.com
- foresterpoole
Re: Sunglasses
I read the same article. I had a set of Costa Del Mar's I was using, but I could never see the radio/transponder on the plane I'm training in because of the angle and the polarization. It was great for fishing, horrible for flight training! So I went looking: ended up with a pair of AO's in black, glass lenses and bayonet temples, bought them off Amazon. Other than my wife saying I look like I stepped off the set of "Top-Gun" in the 1980's I like them so far. I know Oakley has a few options without polarization, if your into the wraparound sporty look.
Ed
Re: Sunglasses
That sounds like a direction I need to go. Thanks!eyeflygps wrote:I bought a pair of non-polarized progressive lens Ray-Ban's from glasses.com
Re: Sunglasses
You lucky birds with perfect vision can skip this lead. I found a site that sells clip-on, flip-up, non-polarized sunglasses. YAY! I ordered a pair and will follow-up once in. For you unlucky dudes saddled with nerdy multiple prescription glasses (like me) this may be a viable solution to those bright sunny days and planes with glass cockpits.
https://sunglassrage.com/collections/flip-up-clip-ons
Re: Sunglasses
No perfect vision, so Walmart flipups work for me:
Not sure if they're polarized or not - if they are, it's not noticable in the planes I fly.
Re: Sunglasses
I fly a Cessna Skycatcher, all glass panel Garmin 300. I have tried polarized flip-ups and parts of the screen disappear if the light hits it just right. They work OK with steam gauges, I'm told.
Re: Sunglasses
Perhaps on reason polarization doesn't affect me is that I normally adjust the flipups so they don't obscure the panel, but just my view out the windshield.
Re: Sunglasses
That's OK, Eddie, just as long as your vision is good enough to see (and appreciate) that beautiful woman sitting behind you.FastEddieB wrote:No perfect vision,
Re: Sunglasses
If you know Karen, flattery will get you everywhere!drseti wrote:That's OK, Eddie, just as long as your vision is good enough to see (and appreciate) that beautiful woman sitting behind you.FastEddieB wrote:No perfect vision,
Re: Sunglasses
I just hope it gets YOU everywhere, Eddie. I have my own beautiful woman to flatter.
Re: Sunglasses
I use a pair of non-polarized Dual AV1 bifocal sunglasses - they work great with my Garmin avionics and outside the cockpit too. $99 at Sportys but I'm sure you can find them a bit cheaper.
Cheers
Cheers
Re: Sunglasses
Not much to add except racing a sailboat for years, I learned that brown color glasses cut glare better than any other color.
Dan
Dan
Re: Sunglasses
And the readers work great, unless I also have myopia,amblyopia, presbyopia, and astigmatism which I do. I tried contacts without much success.MackAttack wrote:I use a pair of non-polarized Dual AV1 bifocal sunglasses - they work great with my Garmin avionics and outside the cockpit too. $99 at Sportys but I'm sure you can find them a bit cheaper.
Cheers
