Maybe he is going to use it for exhibition. Never say never. You don't know that.
Again, I'm not suggesting that it's a good idea or makes sense. I would sell the LSA and purchase a Mooney. If you don't like LSA limitations, don't purchase an LSA.
Can convert LSA to E-LSA to fly faster than 120 kts.?
Re: Can convert LSA to E-LSA to fly faster than 120 kts.?
If you take it out of LSA limits, then your airworthiness certificate is invalid, And the plane illegal to fly, until a new airworthiness in some other subcategory (other than E-LSA) is issuedTimTaylor wrote:I'm not sure you are correct when you say, "you cannot do the change." If you take it out of LSA limits, it MIGHT be possible for it to fall within some other classification, but it would no longer be an LSA and could not be flown by a Sport Pilot or someone operating under Sport Pilot privileges and limitations.
- Bob
Correctcomperini wrote:If you take it out of LSA limits, then your airworthiness certificate is invalid, And the plane illegal to fly, until a new airworthiness in some other subcategory (other than E-LSA) is issuedTimTaylor wrote:I'm not sure you are correct when you say, "you cannot do the change." If you take it out of LSA limits, it MIGHT be possible for it to fall within some other classification, but it would no longer be an LSA and could not be flown by a Sport Pilot or someone operating under Sport Pilot privileges and limitations.
Turns out the European manufacturer has clarified the issue for me. You can order the plane two ways from their factory: 1) as an S-LSA that is limited to 120 Its and 2) as an Experimental Exhibition Racing with a constant speed prop that can exceed 120Kt which also means you need to be a private pilot to fly it. There is no option to order and an S-LSA and convert at another point in time. They also suggest that you can register as a glider instead of a aircraft and then there is no medical requirement either but you need a glider rating. This seems way to risky for me as who knows what may happen in the future should the FAA catch-up on the fact that there are many folks flying around in motor-gliders with no medicals whatsoever just like they did with fat ultralights.
By definition, you should also be able to order it as an E-LSA at the time of purchase.c162pilot wrote:Turns out the European manufacturer has clarified the issue for me. You can order the plane two ways from their factory: 1) as an S-LSA that is limited to 120 Its and 2) as an Experimental Exhibition Racing with a constant speed prop that can exceed 120Kt which also means you need to be a private pilot to fly it. There is no option to order and an S-LSA and convert at another point in time.
- Bob
You dont need that option, you simply order the S-LSA version and convert it yourself "at another point in time" with your local DAR that's qualified to do so.c162pilot wrote:......There is no option to order and an S-LSA and convert at another point in time.
There is a big difference between flying around in a motor glider and what used to happen with fat ultralights. With the motor glider you must have a pilot certificate, flight review, and currency if you are carrying passengers.c162pilot wrote:Turns out the European manufacturer has clarified the issue for me. You can order the plane two ways from their factory: 1) as an S-LSA that is limited to 120 Its and 2) as an Experimental Exhibition Racing with a constant speed prop that can exceed 120Kt which also means you need to be a private pilot to fly it. There is no option to order and an S-LSA and convert at another point in time. They also suggest that you can register as a glider instead of a aircraft and then there is no medical requirement either but you need a glider rating. This seems way to risky for me as who knows what may happen in the future should the FAA catch-up on the fact that there are many folks flying around in motor-gliders with no medicals whatsoever just like they did with fat ultralights.
Also I believe that to certify as a motor glider you need to meet a certain aspect ratio for the wing design, but I don't have time to look up the specifics right now.
I would have thought there is some definition of what constitutes a glider or motor glider. I seriously doubt you can certify any LSA as a motor glider, unless it is one. The beauty of the motor glider option is if you have failed your last medical and can't get a new one, the motor glider would be a decent option.3Dreaming wrote:There is a big difference between flying around in a motor glider and what used to happen with fat ultralights. With the motor glider you must have a pilot certificate, flight review, and currency if you are carrying passengers.c162pilot wrote:Turns out the European manufacturer has clarified the issue for me. You can order the plane two ways from their factory: 1) as an S-LSA that is limited to 120 Its and 2) as an Experimental Exhibition Racing with a constant speed prop that can exceed 120Kt which also means you need to be a private pilot to fly it. There is no option to order and an S-LSA and convert at another point in time. They also suggest that you can register as a glider instead of a aircraft and then there is no medical requirement either but you need a glider rating. This seems way to risky for me as who knows what may happen in the future should the FAA catch-up on the fact that there are many folks flying around in motor-gliders with no medicals whatsoever just like they did with fat ultralights.
You are mostly right, you wouldn't have to be a private or higher. Unless the horsepower is increased above 180, or it is extensively modified a recreational pilot would be able to fly it.TimTaylor wrote:If you take it outside the LSA limits, I don't know how it would be classified, but you would definitely need a Private or higher to fly it. A Sport Pilot can only fly LSA. You would also need a current medical or Basic Med.
What is so different about motorized gliders that makes medicals unnecessary ?
Actually there have been a few SLSA motor gliders. The Lambada is one.TimTaylor wrote:I would have thought there is some definition of what constitutes a glider or motor glider. I seriously doubt you can certify any LSA as a motor glider, unless it is one. The beauty of the motor glider option is if you have failed your last medical and can't get a new one, the motor glider would be a decent option.3Dreaming wrote:There is a big difference between flying around in a motor glider and what used to happen with fat ultralights. With the motor glider you must have a pilot certificate, flight review, and currency if you are carrying passengers.c162pilot wrote:Turns out the European manufacturer has clarified the issue for me. You can order the plane two ways from their factory: 1) as an S-LSA that is limited to 120 Its and 2) as an Experimental Exhibition Racing with a constant speed prop that can exceed 120Kt which also means you need to be a private pilot to fly it. There is no option to order and an S-LSA and convert at another point in time. They also suggest that you can register as a glider instead of a aircraft and then there is no medical requirement either but you need a glider rating. This seems way to risky for me as who knows what may happen in the future should the FAA catch-up on the fact that there are many folks flying around in motor-gliders with no medicals whatsoever just like they did with fat ultralights.
it is classified as a glider instead of airplane. No medical is required for a glider.Warmi wrote:What is so different about motorized gliders that makes medicals unnecessary ?
My thinking does not even include Recreational Pilot since I have never seen or heard of anyone who is one.3Dreaming wrote:You are mostly right, you wouldn't have to be a private or higher. Unless the horsepower is increased above 180, or it is extensively modified a recreational pilot would be able to fly it.TimTaylor wrote:If you take it outside the LSA limits, I don't know how it would be classified, but you would definitely need a Private or higher to fly it. A Sport Pilot can only fly LSA. You would also need a current medical or Basic Med.
My point was, I don't think you can certify a C162 or CTLS or CTSW as a motor glider just because you want to or because you have modified it and it no longer meets the definition of an LSA.3Dreaming wrote:Actually there have been a few SLSA motor gliders. The Lambada is one.TimTaylor wrote:I would have thought there is some definition of what constitutes a glider or motor glider. I seriously doubt you can certify any LSA as a motor glider, unless it is one. The beauty of the motor glider option is if you have failed your last medical and can't get a new one, the motor glider would be a decent option.3Dreaming wrote:
I do know a recreational pilot. I also provide it as an option to students who ask about a sport pilot rating purely from a cost perspective.TimTaylor wrote:My thinking does not even include Recreational Pilot since I have never seen or heard of anyone who is one.3Dreaming wrote:You are mostly right, you wouldn't have to be a private or higher. Unless the horsepower is increased above 180, or it is extensively modified a recreational pilot would be able to fly it.TimTaylor wrote:If you take it outside the LSA limits, I don't know how it would be classified, but you would definitely need a Private or higher to fly it. A Sport Pilot can only fly LSA. You would also need a current medical or Basic Med.
