EGT probes for Rotax 912ULS?
proemer
Postby proemer » Sun Dec 01, 2019 11:00 am
I'm setting up a 4 probe EGT system for a Rotax 912ULS. The display electronics require UNGROUNDED probes, which are a little less common. Two possible types are:
1) Aerospace Logic http://www.aerospacelogic.com/index.php ... uct_id=200
or
2) Electronics International https://www.aircraftspruce.com/catalog/ ... kkey=22203
Any recommendations, suggestions or comments?
Thanks, Pete
Re: EGT probes for Rotax 912ULS?
Postby drseti » Sun Dec 01, 2019 11:33 am
Pete, all I've ever used are grounded probes. They work with all the analog gauges and glass panels I've ever seen. I'm curious what kind of display requires ungrounded.
proemer
Postby proemer » Sun Dec 01, 2019 12:33 pm
I believe the EI and Aerospace Logic graphic displays want ungrounded probes. Also, the very easy to use thermocouple chips (MAX31850) need them.
Pete
Type47
Postby Type47 » Sun Dec 01, 2019 1:43 pm
The Avmap Engibox for Rotax engines needs ungrounded probes.
Type47
2006 Tecnam P92 Echo Super ELSA
I’m not a singing grampa.
Return to “Ask The Mechanic”
