FYI... They swapped the 162's this week. (252>GVL & 29Z > PDK) I had to cancel a flight on Sunday morning in 252 due to a sticky throttle cable. I heard they swapped the planes today. I'm sure they'll replace the cable, but make sure you check the throttle closely...SportPilot wrote:I reserved the SkyCatcher for 12/14 to fly to the SC breakfast club at KSPA. I should arrive around 9:30am.
Topic Deleted By OP
Re: Lunch At KGMU Dec 4
Aviation Real Estate Broker
Did they lube the cable or replace it?SportPilot wrote:252 is good to go.
My plan is to go, but I'll be solo.
Unless anyone wants to hitch a ride. And is not too heavy.
You could either come to Copperhill, or I could pick you up on the way.
Let me know...
Let me know...
Still a go here as well. I plan to be wheels up by 8AM.
I've had frost on my vehicle the last few mornings... might be worth asking LFC to hanger it tonight. They are going to hanger 29Z for me.SportPilot wrote:Lanier opens at 8am and I should be off by 8:30 and arrive by 9:30.
FYI cheap 100LL at KSPA. $4.14 gal self serve….pump is behind Hangar c.
KBNL's 93 non-ethanol pump down for MX back up in a week or so.
That's quality and the way many experienced Skycatcher operators do it.
Patchy, frosty ground fog out at Copperhill right now.
Have to wait a little while to get in the air I'll try to post when I do.
It's about 9:10. Looks like it was not meant to be. Sun can't quite break through. Maybe in a couple weeks.
![Image](https://farm8.staticflickr.com/7468/15832069130_6e5db0a7a8.jpg)
