Landing Technique
Re: Landing Technique
FlyingForFun wrote:Did someone say that?
Yes, but not you.
It's long since been stipulated that different conditions require different techniques. That's what your post restated, very well mind you, and we're all in agreement.
Yet, it's often painted that Ed and I and others are advocating a "one size fits all" approach, and that's just not true. It seeks to make a caricature of our position, making it easier argue against - hence my reference to a "straw man argument".
FlyingForFun
Post by FlyingForFun »
Delete
Absolutely agree! But to make a blanket statement, in an aviation publication, that LSAs need power to overcome a lack of inertia in order to make a smooth landing is questionable.
Guess I must have really blown it last week and didn't know it. Landed without power and had the mains touch down such that my passenger asked if we were on the ground yet :-)
Post by CTLSi »
FrankR
Post by FrankR »
Again, I'm new. I'm probably wrong.
But I find that the ratio between forward/horizontal momentum and downward/vertical momentum needs to be managed ever so slightly, so that there is a bit more forward momentum than there would be in a stall landing.
It just makes landings smoother.
In the Allegro I fly, with 15% flaps, trimmed for 58-66, and the power to idle, the plane will lose altitude with the nose pitch 10% up; and it won't land with a thud. I try to land it slower than that, but I don't feel I need to be near 43.
What am I missing?
I understand the 1.3Vso + 1/2 gust factor. I think I'm advocating for a few more KT's because LSA'a are a bit squirrelly.
Frank
Fayetteville, NC
deltafox
Post by deltafox »
Reference: http://airfactsjournal.com/2013/08/angl ... acle-cure/
AOA might help to visualize how the airplane is performing.
Dave
Did you have a xwind?
Yup -- reported to be at 5kts.
Post by CTLSi »
Post by CharlieTango »
FrankR wrote:Again, I'm new. I'm probably wrong.
What am I missing?
Frank,
Instead of thinking about a ratio of forward vs downward momentum think about controlling the amount of each individually. To land smoothly simply control your sink, In my CT I can do that by moving my stick aft. That generally works fine and of course I can advance my throttle if I run out of stick or if the amount of sink warrants.
Control forward momentum by limiting your airspeed.
Take control of your sink rate and you won't have to add speed for smooth landings.
Post by CTLSi »
CTLSi wrote:
Where is the 'sink rate' instrument? When 3feet off the ground, what should the 'sink rate' instrument show? Just wondering.
Its called a vertical speed indicator and its bottom right on a typical 6 pack.
On your Dynon The graphical Vertical Speed Indicator is located next to the altitude tape.
3' off the ground is too low to be referencing instruments and a VSI's calibration wouldn't be helpful, perhaps a variometer.
FlyingForFun
Delete
Last edited by FlyingForFun on Tue Sep 17, 2013 11:27 am, edited 3 times in total.
Jim Stewart
Post by Jim Stewart »
The only place for your eyeballs is out the window if you're 3 feet off the ground. You're starting to scare the hell out of me...
I believe Wiley Post, a famous aviator, had one eye.
Binocular vision is only a small factor at the angles/distances involved in landing.
Makes me want to try a one-eyed landing next time up!
FlyingForFun
Delete
