Page 2 of 6
Re: 14 CFR part 61, section 61.45(f) Who will do this?
Posted: Thu Jan 08, 2015 7:38 pm
by Torque
3Dreaming wrote:Torque wrote:Go to the bottom of page 9 not page 4, my mistake.
The PTS was written in 2004 when the sport pilot rule first came out. There have been a few changes made to the PTS since then, but it was just a change and not a re-write. In my opinion the single seat checkride was put in place for those existing ultralight pilots who would need to get a sport pilot certificate. There used to be a provision for those pilots to use their ultralight time to get a sport pilot certificate. It was CFR 61.329. It is no longer there, but you can Google it if you want. The PTS still mentions this, and the deadline is almost 8 years past. Just because the regulations say something is possible doesn't make it the right thing to do.
CFR 61.45{f} is not the same as CFR 61.329. You really can not compare the two. I don't believe your opinion matters. In my opinion a lot of laws should not be what they are, that does not change anything.
I posted the last rewrite of the SP practical test standards revisions 1,2 and 3. If you have a newer or updated version post it. I found the latest version I could find.
This is not about ultralight time counting towards anything. One would still need the required training but the checkride can be done in the students own single seat airplane.
Posted: Thu Jan 08, 2015 9:22 pm
Torque wrote: CFR 61.45{f} is not the same as CFR 61.329. You really can not compare the two. I don't believe your opinion matters. In my opinion a lot of laws should not be what they are, that does not change anything.
Tony, there is no reason get all bent out of shape. I was just offering my opinion of why the provision of a single seat checkride was even offered in the first place. You are 100% correct that you can do a checkride in a single place airctaft for sport pilot. If you have someone who will sign you off for the checkride and can't find a DPE call the FSDO there in Springfield. Tell them you can't find a DPE and request that they provide an inspector to do the checkride.
Posted: Thu Jan 08, 2015 11:52 pm
One other thing to remember is a DPE is a private sector individual, and they may not be willing to accept the perceived liability of doing a single seat checkride.
Posted: Fri Jan 09, 2015 5:21 am
by CharlieTango
I knew a guy that got a 'single seat checkride' in his 2-seat KR2. It was a bit too small for him and another person.
Posted: Fri Jan 09, 2015 5:55 am
by Torque
3Dreaming wrote:Torque wrote: CFR 61.45{f} is not the same as CFR 61.329. You really can not compare the two. I don't believe your opinion matters. In my opinion a lot of laws should not be what they are, that does not change anything.
Sorry I did not mean to be so curt.
I do thank you for the comments.
Tony
Posted: Fri Jan 09, 2015 5:57 am
by Torque
CharlieTango wrote:I knew a guy that got a 'single seat checkride' in his 2-seat KR2. It was a bit too small for him and another person.
I think the first to do this in a single seat, people will be talking about it for decades to come.
Tony
Posted: Fri Jan 09, 2015 11:32 am
I didn't think the KR2 met the requirements to be a LSA, because of a to fast stall speed and to high cruise.
Posted: Fri Jan 09, 2015 12:04 pm
by CharlieTango
3Dreaming wrote:CharlieTango wrote:I knew a guy that got a 'single seat checkride' in his 2-seat KR2. It was a bit too small for him and another person.
This was in the early 1990s. It was EAB but the DPE stayed on the ground with a handheld.
Posted: Fri Jan 09, 2015 6:31 pm
by Torque
CharlieTango wrote:3Dreaming wrote:CharlieTango wrote:I knew a guy that got a 'single seat checkride' in his 2-seat KR2. It was a bit too small for him and another person.
This is how its spelled out in 61.45{f} for the Sport Pilot Program.
Tony
Posted: Sun Jan 11, 2015 7:41 pm
by Torque
drseti wrote:That covers practical tests very well. But why isn't there a similar rule for flight reviews?
Its not called a flight review in the Sport Pilot world its called a Proficiency Check and its spelled out how to do this in a single seat at the bottom of page 10.
http://www.faa.gov/training_testing/tes ... 081-29.pdf
Posted: Sun Jan 11, 2015 9:03 pm
Torque wrote:Its not called a flight review in the Sport Pilot world its called a Proficiency Check
They are two different things. A proficiency check is the mechanism whereby a Sport Pilot gains additional category and class privileges (or a higher-rated pilot adds sport pilot privileges in a new category or class), and your reference is correct for that. (Yes, there are provisions for a single-seat aircraft). A flight review is something else again -- it is something every pilot must have accomplished within the previous 24 calendar months, in order to retain pilot privileges. The FAA Order for a flight review states that it must consist, at a minimum, of one hour each of ground instruction and flight instruction. Flight instruction is required by FAR to be conducted in an aircraft with dual flight controls. Thus, it cannot be accomplished in a single seater.
Further, you cannot use a Proficiency Check to satisfy the requirements of a flight review. This is because a Proficiency Check can
only be used to add privileges in a new category or class, for which you are not already rated. A flight review, according to the FARs, can only be conducted in a category and class of aircraft for which you are already rated.
![Crying or Very sad :cry:](./images/smilies/icon_cry.gif)
Posted: Sun Jan 11, 2015 9:14 pm
by Torque
drseti wrote:Torque wrote:Its not called a flight review in the Sport Pilot world its called a Proficiency Check
Yes this is spelled out in the very first page of the PTS. But says nothing of the flight review.
Posted: Sun Jan 11, 2015 9:43 pm
The flight review is covered by CFR 61.56.
Posted: Sun Jan 11, 2015 9:44 pm
It's not in the PTS. The flight review requirement is in FAR 61.56.
Posted: Mon Jan 12, 2015 6:13 am
by Torque
As long as you are a student no flight review is needed.
