No kidding (I have yet to fly in a Rotax-powered plane) -- so that explains why I only see two levers in all the interior pics of Rotax-powered planes...just throttle and carb ice, huh?drseti wrote:Note that none of this applies with a Rotax engine, which has self-compensating carbs and no mixture control.
Broken Throttle Cable
Re: Broken Throttle Cable
Thread hijack and digression time...
Andy / PP-ASEL
- CharlieTango
3 Levers, throttle choke and brakeAJChenMPH wrote:No kidding (I have yet to fly in a Rotax-powered plane) -- so that explains why I only see two levers in all the interior pics of Rotax-powered planes...just throttle and carb ice, huh?
2 levers, throttle & choke.
Andy... I still have your contact info.
We must get you up in a Rotax machine!
- Richard
CharlieTango wrote:2 Levers, throttle and brakeAJChenMPH wrote:No kidding (I have yet to fly in a Rotax-powered plane) -- so that explains why I only see two levers in all the interior pics of Rotax-powered planes...just throttle and carb ice, huh?
2 Levers, throttle and choke (Sportcruiser)
- Fish_eye_gold.jpg (63.94 KiB) Viewed 7226 times
Let me know next time you're in the area!designrs wrote:2 levers, throttle & choke.
![Smile :)](./images/smilies/icon_smile.gif)
Another plane I'm looking at, the Discovery XL-2 (née Liberty XL-2), has FADEC so it's set up the same way: single lever for engine control.CTLSi wrote:In the Rotax 912iS fuel injected engine there is no mixture control knob or choke. Just a throttle. The ECU (computer control) manages fuel and sensors.
Andy / PP-ASEL
AJChenMPH wrote: Another plane I'm looking at, the Discovery XL-2 (née Liberty XL-2), has FADEC so it's set up the same way: single lever for engine control.
There's probably not a jet or turbine engine in production that doesn't use FADEC. Of course, if your realm of knowledge is limited to 3 minutes on Wiki, you might not know that.
"Loss of FADEC" means the engine won't run, but that's no different than saying your engine won't run if you're out of gas. FADEC usually runs (2) simultaneous (redundant) data channels, as well as having a backup electrical source.
The engines typical used in airplanes are based on 50 year old technology. FADEC is a step towards the modern engines our automobiles have been running for 25+ years. It's an awesome system.
The Liberty XL is a neat little airplane. It has a few quirks, but it's a lot of airplane for the money. I test flew one before buying my Cirrus a few years back.
I like the excerpts on your website, it's a shame there's no copy on Amazon.drseti wrote: I did indeed file an ASRS report, just for good measure. The Navy hospitality was great. I wrote the incident up in two chapters of my book "Winging It With Dr. Paul" (now long out of print). Excerpts at: http://avsport.org/publicat/nonfict/goaround.htm and http://avsport.org/publicat/nonfict/navy.htm
Have to go study now, the written test is in 66 hours!
Do you recall what the quirks were/are? I've read somewhere that it's a little trickier to land than some other planes, but wasn't able to find any elaboration...BrianL99 wrote:The Liberty XL is a neat little airplane. It has a few quirks, but it's a lot of airplane for the money. I test flew one before buying my Cirrus a few years back.
(What was I saying about a thread hijack?)
Andy / PP-ASEL
Cramming for 66 hours?!? I'll bet you didn't even do that in grad school.rezaf_2000 wrote:Have to go study now, the written test is in 66 hours!
![Shocked :shock:](./images/smilies/icon_eek.gif)
I assume they have better drugs now!drseti wrote:Cramming for 66 hours?!? I'll bet you didn't even do that in grad school.rezaf_2000 wrote:Have to go study now, the written test is in 66 hours!
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
Acually, two pots of black coffee served me well. . .FastEddieB wrote:I assume they have better drugs now!drseti wrote:Cramming for 66 hours?!? I'll bet you didn't even do that in grad school.rezaf_2000 wrote:Have to go study now, the written test is in 66 hours!
Alas, even 5 hour energy couldn't pull it off! Had to reschedule it for Sunday. Wish me luck!FastEddieB wrote:I assume they have better drugs now!drseti wrote:Cramming for 66 hours?!? I'll bet you didn't even do that in grad school.rezaf_2000 wrote:Have to go study now, the written test is in 66 hours!
Just a couple years ago this happened to me. Here is my story:
Had my little EAB in the shop doing end of year condition inspection and maintenance work. IA walks by and points to my throttle cable, he said XYZ needed repaired or it would fail someday. Then he told me to make sure a spring was added so when it broke the throttle would go wide open, he then walked away.
I go back to what I am doing and forget all about this conversation. Mistake number 1. Never added that spring mistake 2.
About 40 hrs flight time later on a take off I hear this voice in the back of my head. Its telling me to turn back to the runway. I cross the numbers at the end of the runway and make a banking turn back. Just as I level wings in a climb parallel to the runway I hear a load bang, the throttle goes to just above idle. I lower the nose and slide the airplane back over the runway and land using the choke to control engine speed. About 5' from touch down I shut down the engine.
If I would have made a straight out takeoff, I would have been over tree's and full grown corn. In a 400lbs low wing taildragger this could have turned out bad.
Tony
Tony
