Hi,
I have a general question about changing the flight schools - after passing the Knowledge test, completing the cross-country, solo & other pre-requisites at one school, is it possible to change flight school and complete the rest of the training(pre-checkride lessons & check ride) at another school?
FB....
Changing Flight Schools
Re: Changing Flight Schools
I've had one student successfully transfer in from another school after completing the first supervised solo and passing the Knowledge test, with minimal lost time and effort. This worked because I knew his previous flight instructor personally, and that instructor was willing to write a letter for my files, recommending that transfer student for post-solo training. The only extra effort required of the student (other than flying with me once or twice before I would solo him again) is that I required the student to take my flight school's pre-solo written test. He aced it!Flyboyz wrote:after passing the Knowledge test, completing the cross-country, solo & other pre-requisites at one school, is it possible to change flight school and complete the rest of the training(pre-checkride lessons & check ride) at another school?
If you are able to coordinate between your old and new schools, this can sometimes work.
The dual instruction required to be logged specifically in preparation for the checkride is, I believe, 3 hours. If you're not changing aircraft models, are current, and were reasonably competent before changing schools, this dual flying (which you're going to be doing somewhere in any case) should be sufficient to satisfy both the instructor and the school's insurance. Before deciding this, the student should take his or her logbook to the new school and talk it over with the proposed new instructor.bshort wrote:Most will want you to fly a minimum amount of hours with a CFI (10 or so)
Flyboyz, not only is it possible but I have done it. I had almost 30hrs when my instructor just quit on me. Literally stopped flying on Sundays knowing all along I could only fly on the weekend as I was traveling 135miles to the Flight School. Well the owner didn't seem to care and I needed 5hrs dual in our Remos G3 so, I changed flight schools. Went to Sarasota to the same flight school my partner trained at. I purchased 10 more hrs of dual and only really needed 3. That was when the instructor told me he was scheduling my check ride. But for the record I used all 10 hrs and learned a tremendous amount that I wasn't taught at the other flight school.
So.. with all that said I now have over 85hrs logged and am thankful that I did change schools.
Best of luck.
Best of luck.
Gene Mohr
Sport Pilot Upgrading to Private
180hrs and counting
180hrs and counting
that must be hard on you 'gmohr', but great to see that were determined to complete your training - cheers for that.... i feel some flight schools are lacking professionalism, unfortunately, they do not realize their actions hurt general aviation industry and discouraging the aspiring pilots......
thanks for sharing ur side of the story!
