How is this an LSA... Not complaining
Re: How is this an LSA... Not complaining
It's lies like that ad that are ruining the LSA movement for everybody.
There is clearly a sticker on the airspeed indicator so that qualifies as an SLA under FAR 04.01 (please note the date before responding about 04.01)
I wonder if the airspeed limitation has been in place continuously since built.
If not, that could be a problem. I think.
No, the certified weight exceeds 1320.Atrosa wrote:There is clearly a sticker on the airspeed indicator so that qualifies as an SLA under FAR 04.01 (please note the date before responding about 04.01)
There is no certified weight. The gross weight is established by the builder. If they say it is 1320, then it is 1320. Even if Van's post a higher gross weight in their specifications.TimTaylor wrote:No, the certified weight exceeds 1320.Atrosa wrote:There is clearly a sticker on the airspeed indicator so that qualifies as an SLA under FAR 04.01 (please note the date before responding about 04.01)
The markings on the airspeed indicator doesn't have any effect on whether it is LSA eligible. Besides gross weight the two other biggest factors are maximum speed at Vh. Notice the placard stating the max continuous power settings. If this is enought to keep it under 120 knots at sea level under standard conditions you are good on that respect. The other will be clean stall speed. If the clean stall speed is actually below 45 knots calibrated I would be surprised.
As I read the panel, there's a redline at 120 kts indicated (that's not how Vh is defined), and a max RPM placard with limits at various altitudes to supposedly prevent one from cruising above 120 kts IAS at any altitude (clearly, whoever did that never read the definition of Vh in FAR 1.1). Then the white arc goes down to exactly 45 kts, suggesting that full flap indicated stall speed is 45 kts (never mind that the LSA rule is about zero flap calibrated stall speed). So, even if the max gross weight has never been above 1320, there's just no way this will ever be an LSA, and some unwary buyer is going to be in violation if he or she tries to operate this plane under Sport Pilot rules.
I just noticed that the bottom of the green arc is 85 kts. This is supposed to represent indicated clean stall speed, so calibrated stall speed clean will come out somewhat higher. This alone quadruples the kinetic energy to be dissipated in a takeoff or landing accident, as compared to a real LSA. If we just shrug this off and disregard the resulting significant likelihood of fatalities in what should be a non-injury accident, we share responsibility for the results. So, thread subject line notwithstanding, I AM complaining!
I don't think the markings have any credibility. Having flown a RV6 I don't remember there being that much difference between stall speed clean and with flaps extended. Also the outer range on the airspeed is in MPH not knots.drseti wrote:I just noticed that the bottom of the green arc is 85 kts. This is supposed to represent indicated clean stall speed, so calibrated stall speed clean will come out somewhat higher. This alone quadruples the kinetic energy to be dissipated in a takeoff or landing accident, as compared to a real LSA. If we just shrug this off and disregard the resulting significant likelihood of fatalities in what should be a non-injury accident, we share responsibility for the results. So, thread subject line notwithstanding, I AM complaining!
I agree, but your claim that the gross weight is more than 1320 still doesn't carry water.TimTaylor wrote:TimTaylor wrote:It's not.
I get it. But we don't know the specified max gross weight, do we? So, maybe it does "carry water." Not only that, but maybe it's correct. I'd be willing to bet whoever built that airplane did not specify max gross at 1320 pounds. I guess it's possible.
My calculations and comments factored that in.3Dreaming wrote: Also the outer range on the airspeed is in MPH not knots.
