I attended Oshkosh from Thursday to Saturday this year. During the week there had been a meeting between representatives of the FAA and the principals of some of the US based LSA manufacturers. I spoke with three of the CEO's and all where optimistic coming out of this meeting. From what I understand more than gross weight is being discussed including top speed, constant speed propellers and retractable gear. It appears the key thing the FAA has not decided on is if the new limits will be absolute values based i.e. Maximum Gross Weight of 750 Kg's or performance based i.e. Gross Weight can be variable but you must demonstrate that the plane stalls at 45 KCAS for example. So still lots of work to be done.
What I learnt from the CEO of a S-LSA and E-LSA manufacturer is that if planes are tested now to higher weights during design, certification and manufacture and certified now at 600 Kgs then they will be able to be re-certified at the higher weight when announced as long as they can demonstrate compliance to the new standards what ever they may be. A good example this would be the Sling 2 as it is currently tested and certified in South Africa to 700 Kgs but de-rated in the USA to 600 Kgs.
However none of this is likely to happen any time soon. The NRPM should be out in about 6 months (perhaps around the time of Sun 'n Fun) and then it will take another 18 months or so to become regulation. Also there as no mention on how this impacts Sport Pilot License.
Regardless in my opinion in general this is good for the LSA aircraft industry.
Update on LSA limits from Oshkosh
Re: Update on LSA limits from Oshkosh
I didn't think "learnt" was a word, so I looked it up. To my surpise, it is.
Thanks for the info.
The changes to LSA should not affect the SP license, other than to allow SPs to fly airplanes captured by the new regs. Since the definition of SP is one who can fly LSA, it would require quite a contortionist re-imagining of the SP rating to outright exclude some LSA from that rating. However, what might happen is that there could be an endorsement to fly airplanes of a gross more than 1320, or Vh more than 120KCAS, or stall greater than 45KCAS, or whatever performance metric, in the same way there is an endorsement for a SP to fly airplanes with Vh greater than 87KCAS.
All good points Andy and I agree with you. If/when it happens I believe that it'll be another endorsement in your log book if you choose to do so. Whatever changes come in the future it won't affect me as I'll still be flying my E-LSA SportCruiser around.MrMorden wrote:Thanks for the info.
One of the true barriers to a person getting a Sport Pilot license in my Chicago Metro area IS the dearth of SP instructors and LSA aircraft for rent. Were the 150 and similar planes to get approved much of that issue would drastically decrease.
Actually, believe or not, Chicago area is not that bad ... There are 2 schools specializing in Light Sport planes with 5 different LSAs. You an also rent Remos planes at Aurora ...
I remember reading about folks driving hundred+ miles for a lesson ... so ,while nowhere near as accessible as for PP certified pilots, we don’t have it that bad.
Here’s a different perspective regarding expanding the weights/performance of LSA aircraft: from outside the airfield fence. As a former glider pilot looking at obtaining a sport pilot certificate the availability of aircraft remains a major barrier in parts of the country.
For example, established flight schools in my area (Omaha, Nebraska) currently do not offer sport pilot training, unless you have your own aircraft. At last check the nearest sport pilot program with aircraft available for rent (Iowa Flight Training) is located in Cedar Rapids, Iowa; that’s a roundtrip of approximately 550 miles. Imagine for a moment you wanted to learn to fly, but you had to drive an 8-hour roundtrip for each lesson.
By expanding the weights/performance criteria to include aircraft such as the Cessna 140/150/152, Piper Tomahawk or Diamond DA20 more existing flight schools would be able to offer sport pilot training and services. In addition, the USAF aero clubs may consider offering the sport pilot training to service members. In my case, such a change would provide at least four flight schools an opportunity to expand their training programs to include light sport.
Several have mentioned the safety aspects of allowing an increase in the weights/performance of LSA aircraft. Others within this forum have briefly touched upon the benefits of standardized weights/performance with our European counterparts. Each has a valid point worthy of further discussion and detailed examination.
From my perspective, looking from outside the airfield fence, changing the weights/performance criteria to include more existing aircraft is logical. Such changes can only serve to improve general aviation and potentially grow the number of individuals within the sport using existing resources.
I agree entirely. However, our objectives (improving GA, growing the pilot population) and the FAA's mandate (reducing number of accidents) do not exactly coincide.Turn & Slip Inn wrote:Such changes can only serve to improve general aviation and potentially grow the number of individuals within the sport using existing resources.
I do not find those mutually exclusive.drseti wrote:. . . our objectives (improving GA, growing the pilot population) and the FAA's mandate (reducing number of accidents) do not exactly coincide.
Just because we improve GA and pilot numbers . . . that does not mean we can't reduce the accident Rate.
If the objective was to reduce "accident numbers," then getting rid of all GA airplanes and pilots would certainly accomplish that.
And, if the FAA's mandate is to eliminate all aviation accidents -- well, we all know how that could be accomplished. ![Sad :(](./images/smilies/icon_sad.gif)
Paul,
Although the mathematic equation you suggest makes sense on paper I’m not seeing it play out in the real world.
If it did wouldn’t we be seeing higher accident and death rates in the heavier aircraft?
The LSA accident record is not bad the heavier and higher stall speed in the 152s, 172s, warriors etc are even better not worse.
Mark Gregor
Mark Gregor
Mark, the significance of KE is that impacts fatality rate, not total accident rate. In an EAA webinar a few years ago, I used 10 years of NTSB data to calculate percentage of accidents that resulted in serious injury or fatalities. The overwhelming majority of LSA accidents were no-injury (walk away accidents). For non-LSAs, something around 30% of reportabe accidents resulted in serious injuries or fatalities. You're right that the accident rate in LSAs is no better than for the GA fleet as a whole. But they result in much lower severity, in terms of injury or deaths. So, when you consider life and limb, the LSA constraints are indeed successful at improving safety.
I would rather make an off-airport landing in a SkyCatcher than in a B747.
That's exactly what the KE equation implies.TimTaylor wrote:I would rather make an off-airport landing in a SkyCatcher than in a B747.
Exactly why I posted it.drseti wrote:That's exactly what the KE equation implies.TimTaylor wrote:I would rather make an off-airport landing in a SkyCatcher than in a B747.
