Float Plane Capsizes in Dyes Inlet
Topics related to aviation provided mostly for humor and amusement purposes. Offensive or abusive posts will be deleted.
HAPPYDAN
Post by HAPPYDAN »
https://www.kitsapsun.com/story/news/lo ... 939754001/
This accident occurred about 5:30 P.M. today. The pilot is OK, but apparently the plane not so much. From the photographs, can anyone identify the plane? It seems to be a very small, possibly home built boat-type hull with sponsons near the wingtips. Just curious. I belong to an EAA club based out of Bremerton National (KPWT), which may have been where the plane was kept.
Re: Float Plane Capsizes in Dyes Inlet
Looks like he might have landed on the water with his wheels down. IDK.
Is this it?
https://www.google.com/search?q=N135PZ& ... 36&bih=754
https://flightaware.com/resources/registration/N135PZ
That’s him and landing a float plane on water with the wheels down will bite you every time. :mrgreen:
It’s a VJ-22 Experimental Amphibian. Appears to be flying since 1995, with numerous owners. Here is a link...
HAPPYDAN
Post by HAPPYDAN »
Hey, thanks for the prompt responses. Looks like you all know your stuff. I don't know the owner, but it's a small community here so I'm sure someone in EAA 406 does. Looks like he should have used a checklist, or at least a "GUMPS" check. A very expensive mistake, indeed.
HAPPYDAN wrote:Looks like he should have used a checklist, or at least a "GUMPS" check. A very expensive mistake, indeed.
With an amphibian, it's a little more complex than a simple "GUMPS". Here's what I was trained to do:
On water, say (and check) "this is a WATER landing. Left main, UP. Right main, UP. Tailwheel, UP. Wheels UP for a WATER landing."
On land, say and check "this is a LAND landing. Left main, DOWN. Right main, DOWN. Tailwheel, DOWN. Wheels DOWN for a LAND landing."
And, always say it out loud. If you didn't hear yourself say it, you didn't do it.
I keep hearing that insurance rates for amphibians are significantly higher ... that would explain why :D
