True if your medical certificate is valid. If not you revert to sport pilot rules and need category and class endorsements in your logbookBTW for any licensed PP out there, all you need is a biannual but I strongly suggest a good checkout in an LSA.
Data is in: Sport Pilots more prone to accidents than GA pil
Jim,Jim Stewart wrote:True if your medical certificate is valid. If not you revert to sport pilot rules and need category and class endorsements in your logbook
I don't believe this is the case. Holder of a PP-ASEL should not need any additional endorsements for LSA, unless they are for tailwheel or sea planes. The requirement is that they adhere to sport pilot rules, i.e. 10K' ceiling, no flying at night, etc. They don't require endorsements for airspace or speeds, as the PP-ASEL does not have restrictions, and the training was received while earning the cert.
Roger Fane
Endorsements
From the 2009 AIM (61.303)
If you hold only a US drivers license and you hold at least a recreational pilot certificate with a category and class rating, then you may operate any light sport aircraft in that category and class, and you do not have to hold any of the endorsements required by this subpart, but you must comply with the limitations in 61.315.
Although I did not explicitly state it, I was referring to excising SP privileges with a PP license and no medical.Jim Stewart wrote:True if your medical certificate is valid. If not you revert to sport pilot rules and need category and class endorsements in your logbookBTW for any licensed PP out there, all you need is a biannual but I strongly suggest a good checkout in an LSA.
The chart in 61.303 makes it easy to see. I was thinking specifically of 61.303(2)(iii)(A)(1) which says “You must comply with the limitations in §61.315, except §61.315(c)(14) and, if a private pilot or higher, §61.315(c)(7).”
NOTE except §61.315(c)(14) and §61.315(c)(7)
Which means you do not need any additional endorsements;
(1) to fly in A,B,C & D airspace or land at airports within them.
(2) The speed endorsement for Vh above 87 kts.
Hence the conclusion all a PP needs is a current biannual.
You can find all this at gpoaccess.gov which is where the FAA website point to for all CFR's.
Thanks to others who have already pointefd this out. This ismy first time back since may last post.
Marcus - WA2DCI
PP ASEL Instrument
Daidalos Greek: Δαίδαλος
PP ASEL Instrument
Here's a table that makes it easy. http://rgl.faa.gov/Regulatory_and_Guida ... kup/61.303
You definitely do not need the logbook endorsements if you hold a private with an expired medical and a valid driver's license.
Has there been any accidents due to lack of medical?
Specifically a medically related problem with a sport pilot.
Or are the accidents just in a sport pilot airplane.
If you count all the pilots transitioning to fly as sport pilots. Standard and LSA airplanes the accident averages might work out better. But who knows how many are doing that.
Most accidents are due to lack of aircraft specific training and unusual handling characteristics in the LSA designs.
Hopefully that does not make Avemco and other insurance companies pull out of the sport pilot market before more easy to fly LSA designs become available.
Moving this thread to the Safety Corner forum.
My old instructor said that I would be a better pilot than someone who trained in a general aviation plane because the CTSW was so very responsive to the simpliest control movement and was so hard to get on the ground.
Another instructor told me "when you move to bigger planes you'll be surprised at how ez it is. The bigger planes stay in place when you are on final and your CTSW doesnt."
I think that is true but since I don't think flying (especially with a passenger) should be an adrenalin sport, I got rid of mine.ussyorktown wrote:My old instructor said that I would be a better pilot than someone who trained in a general aviation plane because the CTSW was so very responsive to the simpliest control movement and was so hard to get on the ground.
We just had to learn techniques for these unique air ships.
I pull back power on downwind mid field and the plane goes to 61 and I add 15 degrees flaps.
If the spirits of Orville and Wilbur are with me, I can coast at 61 kph losing 500 feet all the way down to the numbers. Then I ride along the runway. When I see that I am below the horizon and about a foot above the runway and my speed is 45 or thereabouts I flare.
I do hate being shoved all over the sky because of the thermals but I pretend that I am bombing the Nazi's and the flack is all around me but not hitting me.
I also wear a flight suit (I say because of all the pockets) but I want to go full Walter Mitty.[img]http://i1269.photobucket.com/albums/jj5 ... 1343953944[/img]
(Dan with Dog he rescued this week with his light sport 5 gph plane. Makes that hobby more affordable)
As a Light Sport Student Pilot with solo privledges I have never really flown a heavier Certified GA Aircraft... thinking to go try a Cirrus (flew a simulator once)... any comments on what to expect flying and landing the real thing compared to something like the PiperSport that I've been flying?ussyorktown wrote:... "when you move to bigger planes you'll be surprised at how ez it is. The bigger planes stay in place"
