Exhaust leak
Re: Exhaust leak
ShawnM wrote:And the wire tie is on backwards. :mrgreen:
Nice catch! :mrgreen:
Re: Exhaust leak
Wm.Ince wrote:
3Dreaming wrote:I hope you remove and clean the tank periodically. The quick drains are typically slightly higher than the bottom of the tank, and in my opinion they don't allow for the large rush of fluid to help carry any debris out of the tank.
Totally concur, Tom.
That was a major reason I switched back to the screw-in plug. I feel it removes more lead debris than the quick drain, due to a less restricted exit path. Besides that, it drains faster and is actually a breeze to remove and re-install with my torque wrench.
I change my oil at each annual condition inspection and remove the tank for cleaning every other year. I dont run 100LL at all, ever!! I usually find nothing in the bottom of the oil tank.
