Fuel Pump issue
Re: Fuel Pump issue
FastEddieB wrote:As an interesting footnote:
I replaced my wonky fuel pressure sender with the same part # VDO sender.
When it arrived, it had a red tag attached saying: "Not for use with fuel".
Thought that odd, but its the same part that came on my plane in the first place.
Go figure!
Maybe that's why it went wonky! :)
Re: Fuel Pump issue
Was it this one? This is the most common.
http://www.egauges.com/0-30-PSI-10-180- ... /23224.htm
Re: Fuel Pump issue
roger lee wrote:Was it this one? This is the most common.
Looks very familiar.
My Equipment List seems to list nearly every little thing, but I don't see that.
In any case, the "Not For Use With Fuel" did surprise me.
Re: Fuel Pump issue
Next time you buy NGK spark plugs look on the box.
Re: Fuel Pump issue
And then there's propeller leading edge tape. It's a 3M product, sold by Aircraft Spruce under exactly that name. When you open up the box, there's a warning label provided with the roll of tape: not for use on propellers.
Re: Fuel Pump issue
Here's my original:
It was located on an aluminum bracket attached to the engine.
I relocated the new one off the engine to cut down on vibration:
That was in Feb 2011, and so far so good.
