FAA Amends ADS-B Rule For LSA
Post by CTLSi »
As I predicted, the FAA is going to allow non TSO'd equipment in LSA and experimentals to meet the ADS-B mandate.
Flight Design provides a complete solution under this amendment with Dynon and Garmin 796 WAAS GPS.
http://www.avweb.com/avwebflash/news/FA ... 533-1.html
bottleworks
Re: FAA Amends ADS-B Rule For LSA
Post by bottleworks »
CTLSi wrote:As I predicted, the FAA is going to allow non TSO'd equipment in LSA and experimentals to meet the ADS-B mandate.
It's a good thing that the FAA cleared up the language but this does not mean that a 796 now meets the TSO performance criteria. FD, Dynon or Garmin would need to state that is the case and provide the data to back up the assertion. I'm not aware this has been done.
I think it depends on what definition we ascribe to the term "performance". As a position source, there is little doubt that a 796 is as good as a 430W, they both have WAAS accuracy to within a few meters, and that should be good enough. If you are talking about *all* aspects of a TSO, such as resistance to interference in all attitudes, antenna gain, ect...probably not.
I believe that traditionally LSA/EAB manufacturers do not have to prove they meet every aspect of a TSO (after all, that would be essentially the same as getting the TSO and just as expensive if required), but instead simply need to be functionally equivalent for the task they are designed for. That's why you can have a $5000 Skyview system in an LSA that does everything a $50,000 Avidyne or Garmin setup does in a certified airplane like a Cirrus.
There's the rub :D
EAA has a great position paper on equipping an experimental for IFR (https://www.eaa.org/en/eaa/aviation-com ... operations). An excerpt that seems to apply here:
As with transponders and other equipment discussed previously, GPS equipment must meet the performance requirements of the applicable TSO (in this case, C129), but there is no specific requirement for the equipment to be built under a TSO authorization. However, if the equipment is not built under a TSO authorization, it is up to the owner/operator to verify and document that the equipment performs within the required specifications. It is also the owner or operator's responsibility to document the necessary flight-test data showing that the installation performs within the required accuracy parameters.
By extrapolation, an LSA manufacturer (or other party) would need to document the 796 performed to the level of the TSO.
Post by designrs »
There's a lot of grey area about performance certification. It's not a matter of parking your plane on the "X" at an avionics shop and recording location accuracy. It's more like when some satellites go offline from malfunction or from being obscured (and they do), can your unit compensate and still be accurate?
Also, ADS-B also provides additional parameters in the data stream settings pertaining to reliability. For example, if you use a portable two variables are set in the data stream out which basically are the equivalent of saying "this data is not certified to be accurate".
The FAA is still assessing the functionality and reliability of ADS-B as a basis for the next generation of ATC. At present, due to the limited number of aircraft using the technology, there is not a sufficient sample group for them to study. When they do have greater numbers to study they want to be assured as much as possible of the quality of data that they are evaluating.
nbjeeptj
Post by nbjeeptj »
How would this apply to a SLSA in my case a AMD 601xl, as far as installing it, and getting a OK from the builder that no longer exist?
nbjeeptj wrote:How would this apply to a SLSA in my case a AMD 601xl, as far as installing it, and getting a OK from the builder that no longer exist?
It is my understanding that if there is no one handling support of the aircraft whether it is the original manufacturer or someone else, that you will have to change the registration from SLSA to ELSA. Someone at the FAA told me they were having to go after some aircraft because of this lack of a supporting group, and that the owners were not to happy about it.
