CTLSi wrote:
A slip to landing is NOT to be used to save a bad approach, extended or short. If too high go around. Guys slipping on every landing are definitely wandering away from best practice.
Very few pilots are right in the exact place they need to be, at the perfect speed, from abeam the numbers all the way to the touchdown point on *every* approach. Every approach is different and under different conditions, and most will require some control inputs to correct as the approach progresses.
So at what point do you realize you are high and go around? Short final? turning final? What if you are turning base and you can see you are high...go around? What if you are high abeam the numbers...go around?
It's not as simple as "if too high go around." It's not about "saving a bad approach" it's about the constant corrections in speed, altitude, and direction that go into making *any* approach work out. If you are high and you have time to correct it, then add flaps, slip, etc as needed. If you are low, add power until you are back on the desired glide path.
If you know your abilities and can safely fix an approach that isn't perfect, why wouldn't you? As soon as you know an approach can't be fixed without a lot of intervention or it starts feeling too much like work, sure, it's time to give it up and go around. High winds, night time, a short runway, or other complicating factors mean you should make that decision much easier. But I think adjusting your approach to make it work out when you can is a very valuable skill that promotes pilot proficiency and helps prepare for difficult conditions when they occur.
