Class B, C, and D endorsement
AirBoss52
Postby AirBoss52 » Fri Oct 12, 2018 7:06 pm
I am currently PPSEL, and am going to be operating as Sport Pilot soon.
Because I have been operating in towered air space for 20 years, is an actual endorsement still required to exercise SP privileges in class B, C, and D airports?
Re: Class B, C, and D endorsement
Postby TimTaylor » Fri Oct 12, 2018 7:10 pm
No, you are a Private Pilot. Those endorsements are for Sport Pilots. You won't be operating as a Sport Pilot. You will be operating as a Private Pilot exercising Sport Pilot privileges and limitations. But no, you don't need those endorsements.
By the way, when did your FAA medical expire? If it was valid anytime after July 14, 2006, you can still exercise your Private Pilot privileges and limitations by following the Basic Med protocol. You don't need to limit yourself to Sport Pilot privileges and limitations unless your FAA medical expired prior to July 14, 2006 or you choose not to take advantage of Basic Med.
BS Engineering NC State
MBA Wisconsin
Postby FastEddieB » Sat Oct 13, 2018 7:46 am
Tim has it exactly right.
The day my medical expired, I was limited to Light Sport privileges and limitations, in spite of holding a valid Commercial certificate. Such as no flight above 10,000’, no flight without visual reference to the ground, no night flying and stricter ceiling and visibility requirements. Seemed a bit silly, since an expired medical had no bearing on the skill sets I had acquired over the years, but it was what it was and I followed the letter of the law in my Light Sport Sky Arrow.
But as Tim suggested, BasicMed removes all of those limitations, and makes available a wide new bevy of aircraft. You are still expected to adhere to the Light Sport aircraft’s Limitations, such as they are, but they are usually less restrictive.
If BasicMed is an option, it’s definitely the way to go.
Postby TimTaylor » Sat Oct 13, 2018 12:47 pm
Correct, except you adhere to Light Sport aircraft limitations only when flying a light sport aircraft. When flying a Cessna, Piper, Mooney, etc., you adhere to those. I guess that's obvious, but if he goes Basic Med, he may or may not ever fly LSA. I just wanted to make that totally clear. If I qualified for Basic Med, I would not be flying LSA. I would be flying a Mooney. I love the SkyCatcher and Remos I fly, but I love the M20C even more.
MBA Wisconsin
AirBoss52
Postby AirBoss52 » Sun Oct 14, 2018 7:11 pm
Thanks for all the replies. Unfortunately, Basic Med is not an option for me.
I’m looking at the Arion Lightning as my foray to the world of Light Sport.
Postby Warmi » Sun Oct 14, 2018 7:24 pm
AirBoss52 wrote:Thanks for all the replies. Unfortunately, Basic Med is not an option for me.
Yeah, you can get them relatively cheap -70k or so for a 6-7 years old model. The only potential problem is the engine - Jabirus are pretty rare and unless you plan to work on it yourself , it is going to be hard to find a mechanic familiar with it.
AirBoss52
Postby AirBoss52 » Sun Oct 14, 2018 7:56 pm
Well, that’s the ballpark. And I live pretty close to Shelbyville, so Jabiru maintainers are readily available.
foresterpoole
Postby foresterpoole » Mon Oct 22, 2018 3:33 pm
There are three I know of that are for sale, one at Arion in Shelbyville, one in California and the other in Pennsylvania. All are experimental, all below 70K. Different avionics I think one has an autopilot (PA Aircraft), the others I am unsure of, the one at Arion has been up for sale for awhile now...
Ed
Postby TimTaylor » Mon Oct 22, 2018 3:55 pm
Make sure you check for damage history. I think many of these have damage history.
MBA Wisconsin
Return to “The new Sport Pilot rule makes flying affordable!”
