Talk to me about Teflon fuel lines
Postby FastEddieB » Tue Apr 17, 2018 8:11 am
I’m about to get started on my 5-year rubber parts replacement.
Fuel lines are straightforward enough I can do them myself, as I did last time. Planning to get help on the other rubber parts.
If you switch to Teflon fuel lines, the 5-year replacement requirement goes away, so it seems like a good option.
I have a friend with an RV12 who made the change. But it was a custom kit for an RV12, and was around $600, involving lots of custom fittings. Too rich for my taste just to avoid a few hours of work every 5 years.
His source: https://www.tsflightlines.com/home.html
Looks very slick on his plane, but again, that’s a lot of money.
Question: can one just buy Teflon lines and use stock fittings? I think I read that Teflon lines and barbed fittings don’t mix, so I’d have to track down how many of those I have and replace them with “bulb” fittings.
Or am I missing something fundamental here?
Re: Talk to me about Teflon fuel lines
Postby roger lee » Tue Apr 17, 2018 8:45 am
"If you switch to Teflon fuel lines, the 5-year replacement requirement goes away, so it seems like a good option."
The 5 year doesn't go away. Nothing wrong with Teflon except it's expensive and only addresses what's in the engine compartment. You'll still have to do the 5 year rubber change which is everything else. The fuel hose in the engine compartment is only a small portion. So you spend $600 plus new fittings vs $15-$20 for standard fuel hose. It takes me about 40 minutes to change fuel hose in the engine compartment.
Is it worth $600 for that difference? Only a few make the change, but only you can decide that.
Postby FastEddieB » Tue Apr 17, 2018 8:54 am
roger lee wrote:
The 5 year doesn't go away...You'll still have to do the 5 year rubber change which is everything else.
Yes. I just meant the fuel line part “goes away”.
Thanks. Do you remember the one fuel line that we had to team up on in the Sky Arrow last time?
Postby FastEddieB » Tue Apr 17, 2018 5:49 pm
I don’t think my question was answered...
Can I just buy the right sized Teflon hose, cut it to length, and slide it over the hose fittings and secure with hose clamps, as long as I stay away from barbed fittings?
Return to “Ask The Mechanic”
