Pole Barn progress!
Re: Pole Barn progress!
Postby Wm.Ince » Thu Apr 26, 2018 11:55 am
Eddy,
I'm sure you already thought about this, but what is the biggest general aviation airplane you could fit into that hangar?
CTSW
Postby TimTaylor » Thu Apr 26, 2018 2:35 pm
Wm.Ince wrote:Eddy,
Probably anything with a 40 foot wingspan would fit OK.
Postby Sling 2 Pilot » Thu Apr 26, 2018 4:06 pm
TimTaylor wrote:
Wm.Ince wrote:Eddy,
And needs less than 1700 feet to take off and land :D
Postby FastEddieB » Thu Apr 26, 2018 4:09 pm
42’ hangar doors seem fairly typical for GA hangars, accommodating planes up to Bonanza or Cirrus-sized.
And I was about to post about planes able to operate out of 1,700 grass strips not likely to be larger than that.
Postby drseti » Mon Apr 30, 2018 5:25 pm
For everybody's info:
I just deleted a couple of off-topic posts from this thread. There are other, more appropriate forums for political debate. This one is reserved for sport flying discussions.
Postby FastEddieB » Mon Apr 30, 2018 6:17 pm
Flew up today to pick up Karen and do some weed whacking.
Baby steps!
Postby Wm.Ince » Mon Apr 30, 2018 9:52 pm
drseti wrote:I just deleted a couple of off-topic posts from this thread. There are other, more appropriate forums for political debate. This one is reserved for sport flying discussions.
Thanks Paul, for taking out the trash.
CTSW
Postby MrMorden » Tue May 01, 2018 7:20 am
Sling 2 Pilot wrote:And needs less than 1700 feet to take off and land :D
I saw a lightly loaded King Air take off from a 2000ft grass strip, so I think Eddie will be cool with whatever he wants within reason. :)
Postby Wm.Ince » Tue May 01, 2018 11:27 am
MrMorden wrote:
Sling 2 Pilot wrote:I saw a lightly loaded King Air take off from a 2000ft grass strip, so I think Eddie will be cool with whatever he wants within reason. :)
We used to operate C-12's (King Air 200's) out of Baumholder Army Airfield (1877 feet), Germany, on a routine basis. No big deal.
C-12 was an awesome airplane.
CTSW
Postby FastEddieB » Thu May 10, 2018 6:17 pm
Last week has been mostly grading and moving a bunch of dirt around, and working on HVAC ducting:
The ducting on the garage side, seen here, can stay exposed.
Waiting on some special order windows to arrive to finish the siding.
Slow but steady progress does it.
Postby FastEddieB » Wed May 16, 2018 6:35 am
Quick trip up and back yesterday.
Good news:
They're moving mountains of dirt around still.
To avoid trucking it elsewhere, the owner of the strip is using the extra to fill in next to the runway for future construction:
The septic tanks (septic and pump tank) have been set and the drain field started:
The "grey water" has to be pumped uphill to the only good location for the drain field.
Now, the bad news:
The framing inspector says that as a "garage", that area needs to be "finished". That means drywall over all the wood portions and a ceiling installed, and drywall over the OSB we were going to leave bare:
Needless to say, a lot more expense.
In addition, the windows in the stairwell have to go, unless fireproof versions can be found. Same for the sliding glass door we had intended for access from the house.
Sigh.
Postby ShawnM » Wed May 16, 2018 8:21 pm
Living the dream Eddie, looking great.
You could always remove the windows and slider, drywall over the holes for the inspection and/or CO and then cut out the drywall and reinstall the windows and slider afterwards. :mrgreen: (but you didn't hear that from me)
Fire rated windows and slider? Are you installing "fire rated" drywall in the hangar also? Fire rated windows and doors are really a moot point if you are not. Just sayin' :D
Postby FastEddieB » Wed May 16, 2018 8:35 pm
ShawnM wrote:Living the dream Eddie, looking great.
Let me just say I hear where you're coming from on all counts.
Enough said.
Postby TimTaylor » Wed May 16, 2018 9:10 pm
Is nobody honest anymore?
Postby ShawnM » Thu May 17, 2018 7:05 am
Just look at it as if the new house is a S-LSA and he’s going to convert it to E-LSA. :mrgreen:
Return to “Eye Candy”
