Jabriu Repair
- foresterpoole
Jabriu Repair
OK, got a question about Jabriu engines. I know they are air cooled and direct drive unlike ROTAX which have the reduction gearbox and the hybrid air/liquid cooling. The local FBO works on ROTAX and claims they can repair anything air cooled similar to a Lycoming or Continental. I'm looking at an Arion Lightning that has the 120HP Jab in it, but I'm scared that it may have overheating issues or I have also heard they seldom make TBO. I'm concerned that the A&P might open the cowl and scratch his head. They have never seen one, but again said that they could work on it, I'm not doubting it but how different are they than the standard Lycoming or Continental? I'd hate to buy something I can't get serviced, or get them to do a prebuy and not know what they are looking at...
Ed
Re: Jabriu Repair
That is a valid concern. Just today, I was discussing the issue with a student who was contemplating buying a Jab. I told him that, although I am something of a Rotax expert, I have no experience with the Jabiru engine. Fortunately, we have a local pilot who's on his second Jabiru in an experimental aircraft, so I referred my students to him for advice. But, I would never choose to work on or inspect any engine on which I have not been trained.
Re: Jabriu Repair
Greetings to all, am new to this forum. Am thinking about Purchasing a lightning aircraft. I have narrowed his choice down between this airplane and a CTI. The only reason I’m considering a CTI is because it offers the Rotax engine. I have read many comments on the Jabriu engine and they range all over the place in favor to thumbs down. Rotex has 90% of the market and I know they will be here in 20 years. I Deleigh I would love to have the Rotax 915 turbo charged on the lightning aircraft any ideas
- foresterpoole
Re: Jabriu Repair
First off welcome Colorado! Since I was the OP I'll share my brief experience researching and calling about the engines. First off let me say I did not buy the plane in question, though it was not due to the engine or anything else. I took a serious look at my mission, budget and hours flown and realized that rental was a far cheaper alternative. I'm not writing off ownership, but the price has to be right and the plane has to fit my needs and budget.
So on to your question: Jabriu engines have a mixed past. In Australia (their native country of origin) they had a seemingly high failure rate, which lead to a serious investigation (almost 2 years) and limitations during that time. This has since been cleared up, but the underlying reason was that A&P's were not trained in the eccentricities of the engine and were missing signs of wear. To quote the findings:
All that to get to my point: I would not (and have not) discounted Jabriu powered aircraft in my search of a plane. I would however get a through inspection from an EXPERIENCED Jabriu mechanic before I would purchase one and understand parts and experienced A&P's will be lacking in the US. Also, if your into the Arion Lightning, Nick at Arion has a whole host of engine fitment options, including Lycoming, UL, etc. So if you are looking to build or even swap engines those may be options to think about. You will need to check on what you can and can not modify based on the way it was registered and airworthiness certificate. Most of all I'd recommend calling Nick Otterbach at Arion. They just were named the Jabriu engine support and repair shop for North America, so they will have experts in both the airframe and engine. I have talked with Nick on the phone a couple times and he is very helpful and very willing to answer any and all questions I've ever asked.
So I take this as you (or your A&P) better know the engine of you can easily overlook issues. There also were multiple reports of overheating, both in Jabriu airframes and in experimental applications. Airflow to the rear cylinders was considered problematic and could cause overheating under hot/humid conditions, which in turn creates excessive wear issues. Jabriu has addressed some of these issues with changes to the lifters, baffling recommendations and changes, and better training for A&P's. It's my understanding they also redesigned the engines recently in an effort to correct past deficiencies.The failures experienced can generally be attributed to the maintenance practices, not necessarily poor quality of maintenance but… any deviation from the current Jabiru recommendations does appear to introduce conditions that can rapidly deteriorate the engine health to the point of failure. Hence, the current maintenance schedule (in particular 25hr oil changes) and the maintenance requirements for cylinder head inspections/maintenance per Service Letter JSL014 can be expected to provide for an acceptable level of reliable operation if they are adhered to with some vigilance.
Ed
