Question about wings not being level on a Sting plane
Re: Question about wings not being level on a Sting plane
Postby 3Dreaming » Tue Oct 10, 2017 4:07 pm
As a reference point, tubeless tires are not common on light aircraft. Even if the tire itself says tubeless they often have tubes installed.
Postby Warmi » Tue Oct 10, 2017 4:08 pm
drdehave wrote:I once mounted two tires on my Sting (it uses utility trailer tires and tubes; sound like you have aircraft tires), long before I knew what I was doing. Then I went flying, came back and parked the plane in the hangar. One tire blew up, whilst I was sitting at my desk recording in my logbook. Be sure you know what you're doing regarding mounting and balancing your tires. They can be pretty dangerous--or at least annoying--done wrong. This older video of mine is a start: https://www.youtube.com/watch?v=OqpfFhJax1Y&t=2s
I am not actually doing it myself - have a mechanic do it for me ( so I can watch ). I also spoke to the dealer and the manufacturer of the tires - got both to sign off on the type of tires I am planning to put it.
drdehave
Postby drdehave » Tue Oct 10, 2017 6:42 pm
First I've heard of using tubeless tires without the added safety of a tube. Learn something every day...
(I'm so happy my tires are $16 each, and a tube runs about $8.)
Postby Warmi » Tue Oct 10, 2017 6:58 pm
My original tires sell for $89.
The new , tubeless rated, tires run $180 each.
drdehave
Postby drdehave » Thu Oct 12, 2017 12:28 pm
10/12/2017: Deleted.
Return to “Ask The Mechanic”
