Overheat Detection System
Researcher1
Postby Researcher1 » Fri Oct 28, 2016 8:04 am
Working on an experimental mid-engine aircraft and need some help on Fire or Heat detection systems as the engine will not be visible from the cockpit.
Have been looking around the web but drawing a blank at the moment...
Could anyone point me in the correct direction please?
