Board index
Sport Pilot Talk
* * * CHECK Out the Sport Pilot Talk Flight School and Rental Finder Map! * * * It is currently Thu May 23, 2013 5:05 am
Post new topic Reply to topic  [ 5 posts ]
Author Message
PostPosted: Sat Mar 24, 2012 6:12 pm
Offline
Hello pilots.
I would like to hear your opinions, ideas, suggestions.
I have a possibility to sell okume plywood with 2 types of glue phenolic and normal. High quality plywood. I will build my plane with this plywood.
Fine thickness, 1.5 mm (0,060"), 2mm (0,078"), 2.5mm (0,098") and 3mm (0,011")
The size plywood produce is 2.500x1.200 (98,5" x 47,24"). Density 450 kg/m3
Could I sell it in pieces cutting it in half.
Could it be of interest to all aircraft builders?.
What do you think?.
thanks
_________________
open/search to new business
www.solynubes.es
www.vidabliss.es
Top
 Profile
PostPosted: Sat Mar 24, 2012 8:57 pm
Offline
I would think that if you can build and fly a successful experimental aircraft with this plywood, and post design information online, that will improve your chances of marketing the plywood as a viable aircraft construction material. Good luck!
_________________
AvSport of Lock Haven
Top
 Profile
PostPosted: Sun Mar 25, 2012 8:40 am
Offline
solynubes wrote:
Hello pilots.
What do you think?.
thanks
Cut in half it might bo to small for some applications, but the smaller pieces would be just right for the model airplane/hobbyist market.
Top
 Profile
 Post subject:
PostPosted: Mon Mar 26, 2012 10:06 am
Offline
I don' know if you are considering selling the wood in your country or exporting it to the US. The Gibson Guitar company has had a huge legal problem with imported wood. The US government seized a large shipment from India because of questions of where it came from and how it was processed. I do not know if this would be a problem with your wood and your company. I do know that if the wood is seized, the chances of getting it released are small.
Top
 Profile
 Post subject:
PostPosted: Mon Mar 26, 2012 10:31 am
Offline
Hello Jim.
the wood is 100% legal, is okume, in thicknesses thick, is used in houses, furniture, boats, shelves, in europe, usa, asia .....
Aircraft Spruce, also sells. but very expensive, and has thin plywood (fine 0,060")
no problem.
_________________
www.solynubes.es
www.vidabliss.es
Top
 Profile
Users browsing this forum: Bing [Bot], Google [Bot] and 0 guests
Search for:
Jump to:
Archive
