Scooper wrote:Shawn, is your GDL 82 installed, and if so how difficult was the installation?
Hi Stan,
Yes, it's installed and works great. Since I now wake up the ground base towers my GDL-39 3D receives the complete traffic picture (dual band receiver) and displays it on my Aera 660. (as well as my iPhone and iPad running foreflight when I use it for backup)
Very, very easy install. Mine took a bit longer as I had to make an avionics shelf behind the copilot panel since I didn't have one from the factory, only on the pilots side. I also added a dedicated push/pull 5A circuit breaker. The other option is to wire it to your transponder power so they are both on at the same time, providing you have the proper circuit breaker rating.
Avionics shelf:
- avionics_shelf.jpg (37.52 KiB) Viewed 17225 times
If you dont install the optional "push to test" button and the anonymous switch it'll go even faster. I installed both.
Here's the copilot panel showing the dedicated circuit breaker, far right one on the bottom and the optional switches (anonymous mode and push to test) are to the right of the Dynon EMS.
- co-pilot panel.jpg (60.53 KiB) Viewed 17225 times
If you plan on installing this yourself be sure you have a high density d-sub pin crimper. The unit has a 15 pin high density connector. You'll also need 4 antenna connectors, 2 BNC and 2 TNC along with some RG-400 cable. Minimum 6.5 feet just for the GPS antenna and another piece to install between your transponder and the GDL-82.
I mounted my antenna under the cowling on an antenna shelf I installed for both my GPS antennas. Seen here:
- antenna shelf.jpg (57.98 KiB) Viewed 17225 times
The wiring is very easy. Basically power, ground, the USB connector (this is a 6" pigtail that's included) for programming and two wires for the optional switches/buttons.
Once installed you power it up and run the GDL-82 programming software. You then program in your tail number, flight category, stall speed, tell if if you have the optional inputs wired, how far from the nose of the airplane the antenna is located in feet and if you have a single or dual band receiver.
The software is very easy to navigate and you can also monitor the GPS signals and and status. You also use the software for any firmware updates to the GDL-82.
I'd highly recommend the GDL-82 to anyone considering other equipment. This ADS-B unit is top notch.
Hope this helps.
