Board index
Sport Pilot Talk
* * * CHECK Out the Sport Pilot Talk Flight School and Rental Finder Map! * * * It is currently Mon May 20, 2013 12:18 pm
Post new topic Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
Author Message
 Post subject: 1946 Champ 7AC
PostPosted: Sun Apr 22, 2012 9:05 pm
Offline
I'm looking forward to my first lesson in a 1946 Champ 7AC on Tuesday. I was hoping to fly today, but the weather was IFR all morning. I did a preflight with the instructor (who is 82 years old!) and seems to love the plane.
I'll post a report after I fly.
Top
 Profile
 Post subject:
PostPosted: Tue Apr 24, 2012 7:59 pm
Offline
You will love the old bird!
_________________
"Keep on Draggin"
Top
 Profile
 Post subject:
PostPosted: Wed Apr 25, 2012 5:51 pm
Offline
First flight in the Champ was great!
Very honest plane to fly. Every time you change the pitch or roll, you need to be on the rudders. 70kts cruising speed. Something I really liked is that there is nothing really to look at on the panel to distract you. Just an occasional glance at the altimeter and ball, and otherwise you get to enjoy the scenery outside the plane.
It flies nothing like a light sport. It's more like flying a 182 (plane feels heavy and stable).
Top
 Profile
 Post subject:
PostPosted: Wed Apr 25, 2012 7:09 pm
Offline
I enjoy flying the Champ as well, but see if you still think it feels "heavy and stable" in turbulance or when landing in a gusty cross wind. You may just be a better tail-wheel pilot than I.
Top
 Profile
 Post subject:
PostPosted: Wed Apr 25, 2012 7:44 pm
Offline
It was my first flight! I'll let you know.
Top
 Profile
 Post subject:
PostPosted: Fri Apr 27, 2012 4:12 pm
Offline
Had another great lesson today. Interestingly, the plane is easier to land, than take off. But we had winds variable at 8, so there was some crosswind.
Top
 Profile
 Post subject:
PostPosted: Fri May 04, 2012 9:31 pm
Offline
Lessons are still going well. I'm still finding the plane relatively easy to land (in 3 point/full stall landings), but hard to control on take off.
The hardest part seems to be right after takeoff, when the plane is flying slow, and starts getting tossed around by the wind. With only 65 hp pulling the plane, it's a challenge to keep it flying straight.
Any suggestions from Champ pilots?
Top
 Profile
 Post subject:
PostPosted: Fri May 04, 2012 9:48 pm
Offline
Try lowering the nose a bit after you've cleared all obstacles, make a shallow climbout, and get a bit more airflow across the controls. That will make them more effective, especially the rudder (though it will increase your time to climb).
_________________
AvSport of Lock Haven
Top
 Profile
 Post subject:
PostPosted: Sat May 05, 2012 6:26 am
Offline
I guess one thing to try is to not focus on the actual takeoff.
IOW, assuming you've lifted the tail and are rolling nicely and straight down the runway, at rotation speed just slightly lower the tail again to a normal climb attitude, and the plane should cooperate by flying off the ground when it's ready. Be patient. I mean, don't pull it off the ground at a specified speed, which your comments suggest may be too slow.
Of course, in a gusty crosswind, you'll want to stay on the ground a bit longer and pull the plane off the ground a bit more sharply.
BTW, my above comments don't only apply to tailwheel aircraft, except for the lifting the tail part.
_________________
Top
 Profile
 Post subject:
PostPosted: Sat May 05, 2012 10:39 am
Offline
I don't know what speed you are climbing out at but should be about 60. As stated previously you may need to climb out a bit shallower but 60 should put you at the right climb for that bird. Also pay attention to sticking with the rudder, don;t get lazy. If you climb out at 60 and stick with the rudder, you should not have a problem at all. If you are having problems, your instructor should have you landing and taking off for a good part of your lesson until you get this down pat. Good luck! You will get it!
_________________
"Keep on Draggin"
Top
 Profile
 Post subject:
PostPosted: Tue May 08, 2012 10:51 pm
Offline
Honestly, I see waaay too much of that. A lot of light tailwheel aircraft do a LOT better if you just keep the stick neutral, let the tail lift off on it's own, and then add a tiny bit of back pressure. The plane is READY to fly, don't force it to stay on the runway.
Ryan
_________________
Independent Flight Instructor at http://www.TexasTailwheel.com. Come fly tailwheel LSA's.
Top
 Profile
 Post subject:
PostPosted: Wed May 16, 2012 8:00 pm
Offline
Ryan
Not my experience.
I taught that directional control could be maintained one of two ways on takeoff:
1) if the tail is down, the tailwheel steers.
2) if the tail is up and in the airstream the rudder steers.
In between is where the danger lies, where a sudden gust from the side can leave the pilot with NO directional control at all and put him or her aimed at the runway edge in a heartbeat. True on takeoff and landing. My experience is in Citabrias and Cubs and Cropdusters up to about 300 hp.
BTW, gyroscopic precession can be huge on the bigger engined planes, so lifting the tail needs to be done smoothly. Still needs to be done, though, IMHO.
_________________
Top
 Profile
 Post subject: 7CCM
PostPosted: Mon Jun 11, 2012 10:02 am
Offline
I'm flying a 7CCM Champ with a wing replaced by American Champion. My landings, many, have been better than the takeoffs but they are coming around. Over-correction has been my problem but as the hours increase, that is being slowly whittled away.
This Champ lands faster because of the shorter wings but hasn't been a problem. After bringing the stick to neutral on takeoff, it does fly itself off the ground. A little lowering of the nose and it climbs steadily. It trims out nicely and so far, no complaints on performance. I've already been into grass with it, flown in windy conditions, and received emergency engine out training.
Learning a lot and enjoying it. It's a great platform to learn from and I'm looking forward to soloing in the next few hours. My wife is now thinking about taking lessons and going for her PPL.
Good luck and keep at it!
_________________
D. Atwood
Top
 Profile
 Post subject:
PostPosted: Tue Jun 12, 2012 9:04 am
Offline
After our last kid left the nest my wife said it was her :D time to move from the right seat to the left. I was partner in a 7AC and told her when she mastered it, we would move on to the 172. It was a great help to her as she had the critical stick and rudder skills. The 172 was very easy and she just turned 70 and still loves flying. I just turned 78, been flying for 60 years, got the Wright Pilot Master Pilot Award last year and we still enjoy the thrill of flying. Been part owners of many aircraft but now are enoying the new Cessna Skycatcher. Can't get her out of the left seat so I can finally enjoy more sight seeing time.
Top
 Profile
 Post subject:
PostPosted: Tue Jun 12, 2012 9:20 am
Offline
Heck, that was no good for her. It didn't even have a left seat.
Congratulations!
_________________
Top
 Profile
Search for:
Jump to:
Archive
