Are there any real discernible differences between the Zodiac 601 XL and the 650? I'm alittle concern that the 650 may actually have less baggage area in the rear than the 601 XL.
Thoughts?
Zodiac 601 vs. 650
The bulkhead that defines the back of the baggage area is about 10 inch farther forward in the 650 that the 601. However the baggage area is higher in the 650. From a volume stand point it may be a wash. You won't get skis in either.
I'm a kit builder and have both sets of plans if you have any other questions.
Ron
Ron
Well I'm not looking to get skis in there, just either a duffel bag, or some camping equipment. The 601 seem to have better baggage area for the camping gear than the 650.rsteele wrote:The bulkhead that defines the back of the baggage area is about 10 inch farther forward in the 650 that the 601. However the baggage area is higher in the 650. From a volume stand point it may be a wash. You won't get skis in either.
Ron
I'm not so sure. The baggage space in the 601 is much lower. I probably really depends on what you are packing.NCPilot wrote:Well I'm not looking to get skis in there, just either a duffel bag, or some camping equipment. The 601 seem to have better baggage area for the camping gear than the 650.rsteele wrote:The bulkhead that defines the back of the baggage area is about 10 inch farther forward in the 650 that the 601. However the baggage area is higher in the 650. From a volume stand point it may be a wash. You won't get skis in either.
Ron
If camping is your thing, the 750 might fit your needs better. It has a lot more cargo space and is of course designed for off field use. It's going to be slower in cruise.
Eh I'm not really a high wing kinda guy. All of the aircraft I've flown are low wings, that's what I'm used to.rsteele wrote:I'm not so sure. The baggage space in the 601 is much lower. I probably really depends on what you are packing.NCPilot wrote:Well I'm not looking to get skis in there, just either a duffel bag, or some camping equipment. The 601 seem to have better baggage area for the camping gear than the 650.rsteele wrote:The bulkhead that defines the back of the baggage area is about 10 inch farther forward in the 650 that the 601. However the baggage area is higher in the 650. From a volume stand point it may be a wash. You won't get skis in either.
Ron
Any Utility aircraft that has low wings?
I'm given to believe that both the 601 and the 650 can be built with wing lockers. You'll still be weight limited, of course, but that should give you room for lots of camping gear.
Wing lockers are quite common. They aren't large, about 8 inches deep and about 20 inches square. Certainly a help. Especially for things like tie downs, extra oil or some beverages to enjoy at the end of your flight. They are not weather tight however. If it rains anything in there will be wet.drseti wrote:I'm given to believe that both the 601 and the 650 can be built with wing lockers. You'll still be weight limited, of course, but that should give you room for lots of camping gear.
Ron
