I am getting ready to do my cross country for SP. The rule states:
One solo cross-country flight of at least 75 nautical miles total
distance, with a full-stop landing at a minimum of two points and one
segment of the flight consisting of a straight-line distance of at least
25 nautical miles between the takeoff and landing locations.
So, my question is about the full stop landing at a minimum of 2 points. Is my home field, where I end my cross country, one of the points? Or do I need to do a full stop landing at 2 other airports? Making for a total of 3 landings.
Thanks
Dave Harding
1946 Aeronca Champ
Cross Country Requirements
Dave, as far as I know your home field counts as one of the stops. In other words, how many landings you log. Typically, a student will take off from point A, fly to point B and land, then fly to point C and land, then return to point A and land.
But last week I did my dual cross country (with my CFI). We went from point A to point B, then to point C, then to point D, and then to point A. But maybe that was because he wanted me to get in one Class B, one Class C, one Class D, track a VOR, get flight following, and also about 25% of the flight was over water. Then today I did my solo cross country, from Point A to Point B ( a different point B) and back to Point A. In both cases I made a full stop landing "at a minimum of two points".
- CharlieTango
X-Country & Class Airspace
Sp does not allow flight through B/C/D airspace without an endorsement:
As far as 2 or 3 locations for landing, I am just going to do a triangle and make stops at 2 other locations. If I am confused, and others have opinions, well, I won't be taking a chance that I am in error. FWIW my route:
KAPV-L22-KDAG-KAPV which works out to 120nm.
Training with your CFI will allow the endorsement to be added to your logbook. Note that Class A airspace is off limits regardless of any training/endorsement.The rule has been designed to incorporate "building blocks", which will allow the Sport Pilot to, with additional training and endorsements:
• Fly in class B, C and D airspace
• Additional category and class endorsements may be added
Dave Harding
1946 Aeronca Champ
1946 Aeronca Champ
OOPS! I'm sorry...I've caused some confusion here. Please disregard my response above. I am training for a regular PPL in a Cessna 172 and therefore I am in a different program. The reason I am in this group is, I want to fly aircraft in the Light Sport category as well as in the Normal and Utility categories.
