Flight review
theoarno
Flight review
Postby theoarno » Fri Oct 27, 2017 11:22 am
As a light sport pilot is a Bi-Annual flight review required?
Re: Flight review
Postby 3Dreaming » Fri Oct 27, 2017 12:26 pm
Yes, it is all spelled out in CFR 61.56. If you are a sport pilot it must be done in a light sport aircraft. If you hold other than a sport pilot certificate you can do it in any aircraft you are rated for. In that case the instructor must be able to act as pilot in command if you can not.
Jim Hardin
Re: Flight review
Postby Jim Hardin » Sat Oct 28, 2017 1:37 pm
Keep in mind it is not a test and you cannot "fail' it.
Since you are paying for 2 hours anyway, 1, ground & 1, flight, put it to good use!
Tell the instructor about any area that you are not comfortable with so he can work with you during the flight to include that area.
Whenever I give a flight review, I always work with the customer to try to work in areas they feel they want to explore but with an instructor rather than on their own. Might be working a tower controlled airport or a grass field may tickle your fancy. It is flying and you are there to have fun :D
Re: Flight review
Postby TimTaylor » Sat Oct 28, 2017 1:45 pm
You are there to demonstrate your competency as a licensed pilot. You can't fail, but you won't get signed off if you are significantly rusty and/or unsafe at the discretion of the CFI.
Re: Flight review
Postby MrMorden » Sun Oct 29, 2017 10:53 am
Jim Hardin wrote:Keep in mind it is not a test and you cannot "fail' it.
That’s true, but if the CFI has concerns he could decline to sign off the flight review endorsement. Usually this will be because there is something he wants to work on some more with you, which might cost an hour or two of additional training time. But if he really thinks you are a menace, he could outright refuse to sign you off, and you’d have to pay for another flight review (presumably with another CFI).
Re: Flight review
Postby TimTaylor » Sun Oct 29, 2017 11:39 am
Or get some dual to get yourself back up to speed. Then retake the flight review with him or someone else.
Re: Flight review
Postby 3Dreaming » Sun Oct 29, 2017 5:09 pm
Or you can participate in the wings program, do your 3 hours of flight training in place of a flight review. That way you are legal to fly whether you are proficient enough to have a flight instructor sign off a flight review.
Re: Flight review
Postby drseti » Tue Oct 31, 2017 9:07 pm
I did an EAA webinar a couple of years back titled "Reviewing the Flight Review." You can find a link to the video on my website, at http://avsport.org/webinars.
Scooper
Re: Flight review
Postby Scooper » Wed Nov 01, 2017 5:14 pm
Thanks for the link, Paul. I'm due for my flight review this month, so the timing is perfect.
http://www.eaavideo.org/detail/video/4815712141001
Re: Flight review
Postby FastEddieB » Thu Nov 02, 2017 9:33 am
I just recently started giving flight reviews again recently, giving 3 in the last several months, in a Mooney, a C120 and an RV12.
I try to glean areas where pilots in general may be a bit deficient. I get this from forums, EAA meetings and face-to-face discussions and "hangar talk".
Here's the outline that I put together and currently use:
As far as the flight goes, I try to customize that to the pilot's experience level, aircraft and stated needs. I usually have them plan a very short cross-country and do at least one simulated engine out from directly over an airport.
If it counts for anything, I've been told the pilots got more from our time together doing the BFR than they got out of prior BFR's, which the felt were fairly perfunctory.
rcpilot
Re: Flight review
Postby rcpilot » Fri Nov 02, 2018 7:07 am
Just had my first BFR yesterday. Fortunately, my former instructor was available and willing. He was concerned that no one at the flight school would want to fly in my E-AB and they would make me use the Skycatcher(which I've only flown in once). It was getting bit windy favoring runway 24. He sees I'm using my checklist and asks if that's just for his benefit. I say, no, I actually use it all the time. We takeoff and he has me fly to Gabreski. Of course their runway 24 is closed, winds gusting to 20 knots and we have to use 19. Good he says. Crosswind practice. We do a few stop and goes and then off to the practice area along the South shore of Long Island. According to my GPS my ground speed is a whopping 37 mph. And this is why I don't normally fly on windy days. He has me do stalls and then the engine out drill. Then back to Brookhaven for some touch 'n goes. All in all he was satisfied that I hadn't picked up any bad habits and he signs me off.
Re: Flight review
Postby TimTaylor » Fri Nov 02, 2018 11:59 am
My flight review is in two week at KHKY in Remos GX.
foresterpoole
Re: Flight review
Postby foresterpoole » Fri Nov 02, 2018 3:05 pm
I'm still a year from mine. Although I can say I probably haven't lost the book learning, some of the finer points have gotten rusty. I rely on flight planning software and apps for every nav log I put together, no paper calculations on an E6B since my checkride. I've only been up once when cross winds were more than 10 knots (gust factor not included), and that was with a CFI as a refresher. I had a 172 checked out for this saturday, but they revised the forecast to 9kts gusting 14kts and that was too close to my personal maximums (10kts gusts 15) for my tastes so I cancelled. I'm scheduled to begin complex training next week so it's not like I'll miss out on much, but I almost felt like a wimp calling up and talking to the receptionist. I would like to go up twice a month to keep the skills sharp; however, rental schedules, weather and my job keep my feet rooted on terra firma more than I would have liked post license. To complicate matters my company has now also placed me in charge of our sUAS program and all aviation activities, sounds great right? Well, with a fleet of 5 drones and 5 part 107 pilots (I'm #6) turns out good drone flight days are the best flying days in general, so it's really eating into my seat time. I'm also flying more powerline patrol and timber damage recon right seat than I'd like, it kills me to sit there while someone else handles the controls (no PIC time either). A bonus: I've just about surpassed my PIC time in manned aircraft with PIC in commercial sUAS. I had 2 hours of time this week alone and it's going to get worse with all the timber damage from Wednesday night's tornadoes down here. Now that I've totally got off subject, I'll say a BFR should be something that is a non-event, but for some of us it may take a bit of refresher to polish the dust off... :D
Ed
Re: Flight review
Postby TimTaylor » Fri Nov 02, 2018 4:20 pm
I usually just read through Part 91 to refresh my memory. This time, since it's in the Remos GX, I booked an hour of solo time a few days before my flight review just to make sure I remember where all the knobs and buttons are. Two years ago, he asked me to dial in a VOR and intecept a radial so it took me a while to figure out how to do that with the Dynon and Garmin SL30 in the airplane. I hadn't used VOR in about 10 years.
Re: Flight review
Postby 3Dreaming » Fri Nov 02, 2018 5:18 pm
rcpilot wrote:Just had my first BFR yesterday. Fortunately, my former instructor was available and willing. He was concerned that no one at the flight school would want to fly in my E-AB and they would make me use the Skycatcher(which I've only flown in once). It was getting bit windy favoring runway 24. He sees I'm using my checklist and asks if that's just for his benefit. I say, no, I actually use it all the time. We takeoff and he has me fly to Gabreski. Of course their runway 24 is closed, winds gusting to 20 knots and we have to use 19. Good he says. Crosswind practice. We do a few stop and goes and then off to the practice area along the South shore of Long Island. According to my GPS my ground speed is a whopping 37 mph. And this is why I don't normally fly on windy days. He has me do stalls and then the engine out drill. Then back to Brookhaven for some touch 'n goes. All in all he was satisfied that I hadn't picked up any bad habits and he signs me off.
I didn't see any mention of the 1 hour of required ground training.
Return to “Training”
