Wm.Ince wrote:3Dreaming wrote:This is the FAA's stance, at least for type certified aircraft that are not approved for IFR flight.
I found it. ORDER 8900.1, Volume 5.
5-439 USE OF AIRCRAFT NOT APPROVED FOR IFR OPERATIONS UNDER ITS TYPE CERTIFICATE FOR INSTRUMENT TRAINING AND/OR AIRMAN CERTIFICATION TESTING. The following paragraphs are intended to clarify the use of an aircraft not approved for IFR operations under its type certificate for instrument flight training and/or airman certification testing.
A. IFR Training in Visual Meteorological Conditions (VMC). Instrument flight training may be conducted during VMC in any aircraft that meets the equipment requirements of part 91 , sections (§§) 91.109 , 91.205 , and, for an airplane operated in controlled airspace under the IFR system, §§ 91.411 and 91.413 . An aircraft may be operated on an IFR flight plan under IFR in VMC, provided the PIC is properly certificated to operate the aircraft under IFR. However, if the aircraft is not approved for IFR operations under its type certificate, or if the appropriate instruments and equipment are not installed or are not operative, operations in Instrument Meteorological Conditions (IMC) are prohibited. The PIC of such an aircraft must cancel the IFR flight plan in use and avoid flight into IMC.
Thanks for digging that up for us.
Observing the above, the implication I get is, there must be a CFII providing training or testing during the operation, although, it does not specifically say so.
Any thoughts on that?
It makes for interesting discussion.
Only a portion of the training for a instrument rating is required to be with a CFII. I think it is legal to fly simulated instruments with a safety pilot or regular CFI.
