Good video here of a go-around to avoid a runway incursion:
http://youtu.be/NzvK-_dNPiQ
Go-Around
Re: Go-Around
Yes, he called final. But it seemed like a loooooooooong final (I know the camera lens can make it look really long). And then a bit after calling that final, another male voice called that he was clear of the runway. Then a good bit of time passed. Then the other plane entered the runway mid-field. I don't know what the landing lights are like on the Diamond, but multiple wing lights with a "wig-wag" feature might have made them more visible. I stopped riding motorcycles because despite my Gold Wing having 2 head lights and 2 fog lights, I was still "invisible" to people regularly enough that it stopped being fun.
Re: Go-Around
I view this as a learning experience. The final for the DA-20 (or 40?) does seem long since it took almost 1.5 mins to get to the threshold. Assume a DA-20 approach speed of ~65kts and that gives you over 1.5nm. The pilot did appropriately announce final on his turn from base but I would've like to have heard a 'short final' when he was over the trees on the approach path. Just seems a long time to go without informing UNICOM of your position.
I never heard the traffic on the ground at mid-field but they could've transmitted during the brief conversations in the approaching aircraft.
I too like wig-wag likes. I tell my passengers that I'm lighting myself up like a Christmas Tree when I get within 10 miles of the airport.
Re: Go-Around
Or they could have transmitted on the wrong frequency. I've seen that happen before.dstclair wrote:I never heard the traffic on the ground at mid-field but they could've transmitted during the brief conversations in the approaching aircraft.
Aviation Real Estate Broker
Re: Go-Around
Unfortunately, I've done this myselfFlocker wrote:Or they could have transmitted on the wrong frequency. I've seen that happen before.dstclair wrote:I never heard the traffic on the ground at mid-field but they could've transmitted during the brief conversations in the approaching aircraft.
Re: Go-Around
It's also very easy to turn down the volume for just a second to talk to a student or a passenger, and then forget to turn it back up.
Not to mention an audio panel set up improperly.
It happens.
DAMHIK.
It happens.
DAMHIK.
Re: Go-Around
And sometimes the frequency on the chart doesn't match the frequency in use at the field! I had that experience a couple weeks ago at a small strip in Southern Oregon. The chart and AF/D say 122.9... but someone at the field decided they liked 122.8 better as it's used by a nearby larger airport. They posted it on a sign at the field but didn't bother to tell the FAA.
An instructor I knew used to call landings 'what happens when you can't find a good excuse to go around'. I don't plan for go-arounds when I'm coming in to land but certainly do like to keep the possibility available!
Scott K. :: A bunch of silly letters
Disclaimer :: Listen to me at your own risk. These are just my opinions...
Re: Go-Around
Hmm... I've flown that Diamond, and I'm pretty sure that's my flight instructor conducting the check out. I'll have to ask him about it.
