My instructor's preferred DE has temporarily lost priveleges. Not sure why, but he's working to get reinstated. He should have an answer from the feds in a few days. I've read stories where pilots have had to re-do their checkrides because of the DE. Want to avoid that if possible!
Thoughts or advice?
There are a couple other DEs nearby, but I would have to fly to their home base for the practical. That would add several hours' rent to the checkride cost.
Horatio
Cleared for the checkride, but...
SP-ASEL (tailwheel)
Luscombe 8A
Luscombe 8A
Re: Cleared for the checkride, but...
Check with those other DPEs, Horatio. One of them might be willing to fly or drive to you (for reimbursement of travel expenses, of course, but that might be cheaper than flying to them). Plus, it's always a good idea to do your practical exam out of your own airport. Home court advantage, and all that...
Oh, and congratulations on reaching this wonderful milestone.
Thanks, Paul. Honestly, I don't mind the extra cost, and it would be fun to plan a cross country to take the checkride.
Would I need to have my instructor come along, in case for some reason I were to fail the flight test?
SP-ASEL (tailwheel)
Luscombe 8A
Luscombe 8A
When he is signing you off for the flight to the checkride you could always have him sign off a solo cross country flight from the checkride airport back home on a sticky note just in case. That way you can fly back home. Not that you will need it.Horatio wrote:Thanks, Paul. Honestly, I don't mind the extra cost, and it would be fun to plan a cross country to take the checkride.
First off, Horatio, you're not going to fail it! Your CFI wouldn't have signed you off if you're not ready. Just keep your cool, fly well, and when the examiner asks you a question that stumps you, don't bluff - just say "I don't know."
Now, as for your question, if you plan this as a solo XC, and your instructor reviews your flight planning and endorses you for it, then if for some reason you don't get your SP on this flight (and it could be a paperwork problem, not a failed checkride), then you just fly the return half of the solo XC as a student pilot.
Of course, if your CFI wants to ride along, and you're cool with that, then he or she gets to be your first real passenger as a licensed SP!
Thanks for the vote of confidence. As they say, the ride is mine to fail. Just trying to prepare for a worst case scenario.
SP-ASEL (tailwheel)
Luscombe 8A
Luscombe 8A
I think I remember reading about a DPE in the Las Vegas area.. who got his credentials pulled and then subsequently several of his passed checkride applicants ended up having to do another ride with the FAA. http://www.ainonline.com/aviation-news/ ... aminations I would say you are better off doing the ride with another DPE just in case. No aspersions on this DPE but better safe than sorry.
Carl
Carl
Private Pilot and RV-12 Builder
I'm checking with some local contacts for him over the weekend - I don't anticipate hearing back from the folks I reached out to until Monday, however I think I'll be able to get some good information.
Assuming your instructor followed the appropriate Practical Test Standards, you should be good to go with any Examiner.
While it helps to know the idiosyncrasies of any particular Examiner, to zero in on one kinda hints at "teaching to the test".
If there's any issue at all, your instructor should not hesitate to send you to another Examiner - if you're ready, you're ready, and all the Examiner does is confirm what your instructor has already ascertained - that you're qualified and prepared to be a Sport (or Private) pilot.
And, worse case scenario, a pink slip is not the end of the world - its a learning opportunity. You'll still get your license and be a better pilot for it, and looking back after a decade or more it will barely register as a bump in the road.
Don't Worry - Be Happy!
The only problem I see is that he is doing the checkride in the Champ. I know it is sometimes hard to fine an DPE who will do a Sport Pilot ride in a tailwheel airplane.
Oh, right, the Champ. That's 1220 max gross, so he needs to find a light DPE.
Seems to me the list of DPEs on faa.gov ought to include their weights!
I have a light DPE, just waiting to see if they are willing to do it in a Champ -
Other issue I see is that either he's going to have to fly to them, or pay them to drive to him... All the folks I know are based in NC.
This DE would drive over to Camden. As far as I'm aware, that was the only reason he was preferred.FastEddieB wrote:Assuming your instructor followed the appropriate Practical Test Standards, you should be good to go with any Examiner.
There are DEs in NC, but I'm faced with paying similar fees and mileage, so in the end the costs would be about the same as extra rental time.
And yes, I will need a light DE!
I
SP-ASEL (tailwheel)
Luscombe 8A
Luscombe 8A
In that case, it's a no-brainer. Which is more fun, flying to your DPE, or waiting around for him or her to fly to you?Horatio wrote:in the end the costs would be about the same as extra rental time.
This is all new to me, but you're right. It does seem to be a no-brainer.drseti wrote:In that case, it's a no-brainer. Which is more fun, flying to your DPE, or waiting around for him or her to fly to you?Horatio wrote:in the end the costs would be about the same as extra rental time.
SP-ASEL (tailwheel)
Luscombe 8A
Luscombe 8A
