The manufacturer can say whatever they want. The FAA governs the operation of aircraft in the U.S.comperini wrote:For Aircraft in the S-LSA category, the manufacturer calls the shots. If they say "no" to night flight, then it doesn't matter what equipment you have installed in the plane, and it doesn't matter what kind of pilot certificate you hold. If the manufacturer says "no", that's it.3Dreaming wrote: You are correct the FAR's establish the minimum equipment required for night flight. On the other hand S-LSA aircraft are built to ASTM standards, and I think they go beyond what is required by the FAR's. I don't have access to the standards to give a dirrect quote, but that was my understanding. I hope someone who has a copy of the standards will chime in here. Tom
Why a Sport Pilot license instead of Private?
I agree with this as well, but the manufacture has to follow the ASTM standards too. If the aircraft does not meet the ASTM standards or the FAR's the manufacture can not say it is OK to fly at night.comperini wrote:For Aircraft in the S-LSA category, the manufacturer calls the shots. If they say "no" to night flight, then it doesn't matter what equipment you have installed in the plane, and it doesn't matter what kind of pilot certificate you hold. If the manufacturer says "no", that's it.3Dreaming wrote: You are correct the FAR's establish the minimum equipment required for night flight. On the other hand S-LSA aircraft are built to ASTM standards, and I think they go beyond what is required by the FAR's. I don't have access to the standards to give a dirrect quote, but that was my understanding. I hope someone who has a copy of the standards will chime in here. Tom
The governing document (per the FARs) is the Operating Limitations, which are created by the manufacturer, adopted and issued by the FAA, must be aboard the aircraft, and must be complied with. See http://avsport.org/acft/SportStar_oper_limits.pdf for an example. If they say day VFR only, that is binding (regardless of who operates the aircraft).zdc wrote:If people are going to claim that a sport plane equipped for night flight per FAR's can't legally fly at night because of a prohibition fromt the manufacturer, please cite the governing FAR or FAA legal opinion.
§ 91.327 Aircraft having a special airworthiness certificate in the light-sport category: Operating limitations.zdc wrote:If people are going to claim that a sport plane equipped for night flight per FAR's can't legally fly at night because of a prohibition fromt the manufacturer, please cite the governing FAR or FAA legal opinion.
(d) Each person operating an aircraft issued a special airworthiness certificate in the light-sport category must operate the aircraft in accordance with the aircraft's operating instructions, including any provisions for necessary operating equipment specified in the aircraft's equipment list.
I deleted all the stuff in between, but you can look up the whole reg if you want. Tom
A light sport aircraft certificated in the S-LSA category can't, if the manufacturer says no. To tie this back to the FAA, you'll find these restrictions issued as part of the operating limits assigned to the S-LSA, in accordance with FAA Order 8130.2F. The operating limit in question reads:zdc wrote:If people are going to claim that a sport plane equipped for night flight per FAR's can't legally fly at night because of a prohibition fromt the manufacturer, please cite the governing FAR or FAA legal opinion.
"This aircraft is to be operated under VFR, day only, unless appropriately equipped for night and/or instrument flight in accordance with § 91.205, and when allowed by the manufacturer’s operating instructions."
Also, keep in mind that 14 CFR 91.205 applies to aircraft with a standard airworthiness certificate (it doesn't automatically apply to S-LSAs or any other category of aircraft). For example, for night flight in an experimental, 91.205 applies, only because the operating limits assigned to that aircraft will say "day VFR unless equipped per 91.205". 91.205 might apply to an S-LSA, if the manufacturer even allows night flight. If they do, then the operating limits most likely impose 91.205 for night flight. Bottom line: For S-LSAs (and experimentals), always consult the operating limits assigned to the aircraft.
- Bob
Take a Look
FAA ORDER 8330.2F, CHANGE 5, 1-15-2010zdc wrote:If people are going to claim that a sport plane equipped for night flight per FAR's can't legally fly at night because of a prohibition fromt the manufacturer, please cite the governing FAR or FAA legal opinion.
CHAPTER 4, SECTION 6, PARAGRAPH 126b(5)
Airworthiness Certification of Aircraft and Related Products
126. ISSUANCE OF LIGHT-SPORT CATEGORY AIRCRAFT OPERATING LIMITATIONS.
b. The following operating limitations, as applicable, will be issued as shown below; any
* deviation must be coordinated in accordance with this order:
(5) This aircraft is to be operated under VFR, day only, unless appropriately equipped for night and/or instrument flight in accordance with § 91.205, and when allowed by the manufacturer’s operating
instructions. *
Bryan Cobb
Sport Pilot CFI
Cartersville, Ga
Sport Pilot CFI
Cartersville, Ga
