Page 3 of 4
Re: Limit to 120 KCAS at sea level only with custom EMS - still an LSA?
Posted: Fri May 01, 2020 11:39 pm
Warmi wrote:GA should operate like the automotive industry.
Ah, but the automotive industry has one advantage that GA will never enjoy: massive economies of scale.
Posted: Sat May 02, 2020 5:12 am
drseti wrote:Warmi wrote:GA should operate like the automotive industry.
That is true unfortunately but ... I was talking from the regulatory point of view.
Posted: Sat May 02, 2020 8:40 am
drseti wrote:3Dreaming wrote:
When the original sport pilot rules went into effect the FAA was adamant that an airplane that had previously been certified at a weight above 1320 could not be re certified at 1320.
And not just "could not be." Could
never be.
Actually it is not that it couldn't be certified at 1320, but that it could
never be a light sport aircraft
Posted: Sat May 02, 2020 8:47 am
Warmi wrote:drseti wrote:Warmi wrote:GA should operate like the automotive industry.
I'm pretty sure the automotive industry has some pretty significant regulations that they have to follow.
Posted: Sat May 02, 2020 9:20 am
3Dreaming wrote:
Actually it is not that it couldn't be certified at 1320, but that it could never be a light sport aircraft
Point taken.
Posted: Sat May 02, 2020 10:10 am
They do but that’s not what I am talking about.
We could be arguing here all night long but why ... just go to any automotive forum and see the type discussions they are having - it is is all about... should I do this and how do I do this, none of the regulatory “how many FAA angels can fit on the head of a pin” we see discussed here and on other ga aviation forums.
Posted: Sun May 03, 2020 12:38 pm
The 120kt CAS limit is a limit for *manufacturers* to design to, not for pilots to abide by. Once an airplane is accepted by the FAA as an LSA, you as a pilot can wring whatever performance out of it that you can. If the aircraft type regularly and easily exceeds LSA performance limits, that's a problem between the FAA and the manufacturer, and the pilot need not be concerned at all (unless the FAA revokes the LSA designation for all existing airframes of that type...but then you have a pretty nice lawsuit against the manufacturer).
Posted: Sun May 03, 2020 7:00 pm
by fatsportpilot
MrMorden wrote:The 120kt CAS limit is a limit for *manufacturers* to design to, not for pilots to abide by. Once an airplane is accepted by the FAA as an LSA, you as a pilot can wring whatever performance out of it that you can. If the aircraft type regularly and easily exceeds LSA performance limits, that's a problem between the FAA and the manufacturer, and the pilot need not be concerned at all (unless the FAA revokes the LSA designation for all existing airframes of that type...but then you have a pretty nice lawsuit against the manufacturer).
I'm pretty sure sport pilots can't modify an E-LSA to exceed speed limitations that the pilot also has to obey. Just like a sport pilot can't climb above 10,000 MSL even if the plane has a higher service ceiling.
Posted: Sun May 03, 2020 7:21 pm
by Scooper
fatsportpilot wrote:I'm pretty sure sport pilots can't modify an E-LSA to exceed speed limitations that the pilot also has to obey. Just like a sport pilot can't climb above 10,000 MSL even if the plane has a higher service ceiling.
Sport Pilots can legally fly up to 10,000 ft MSL,
or 2,000 ft AGL, whichever is higher. The FAA doesn't want you to fly into high terrain; it could ruin your day.
Posted: Sun May 03, 2020 7:45 pm
by fatsportpilot
Scooper wrote:fatsportpilot wrote:I'm pretty sure sport pilots can't modify an E-LSA to exceed speed limitations that the pilot also has to obey. Just like a sport pilot can't climb above 10,000 MSL even if the plane has a higher service ceiling.
I know. I mentioned that in a post one page ago but I was giving a fast example and didn't think it was necessary to be that specific.
Posted: Sun May 03, 2020 8:09 pm
fatsportpilot wrote:MrMorden wrote:The 120kt CAS limit is a limit for *manufacturers* to design to, not for pilots to abide by. Once an airplane is accepted by the FAA as an LSA, you as a pilot can wring whatever performance out of it that you can. If the aircraft type regularly and easily exceeds LSA performance limits, that's a problem between the FAA and the manufacturer, and the pilot need not be concerned at all (unless the FAA revokes the LSA designation for all existing airframes of that type...but then you have a pretty nice lawsuit against the manufacturer).
There is no speed limit for the pilot! The limit is for the airplane. If the airplane is modified to where it is to fast, then it can no longer be a LSA. If it is no longer a LSA, then it can't be flown by a by a sport pilot.
Posted: Sun May 03, 2020 9:07 pm
Not just Sport Pilots.
Nobody can modify a E-LSA to exceed the 120 knot Vh limitation, or the 45 knot clean calibrated stall speed limitation, or add a retractable landing gear, or install a third seat, or constant-speed prop, or a second engine, or cabin pressurization, or anything else that would void its Special Airworthiness Certificate. If it's an E-LSA, it has to stay an E-LSA, no matter who is flying it.
Posted: Sun May 03, 2020 10:02 pm
by ShawnM
I guess as long as there are rules to follow someone will be out there trying to circumnavigate those rules. If 120 kts isn't fast enough for you then go get your private pilot rating and buy a Mooney or something even faster.
Posted: Sun May 03, 2020 10:20 pm
Actually I'm pretty sure that a ELSA could be modified with any of those items. It of course could no longer be a ELSA, but it could be changed to experimental exhibition.
Posted: Sun May 03, 2020 11:05 pm
I think Experimental R&D is a possibility. Maybe even Experimental Exhibition. Both of those come with significant operating limitations. Certainly could no longer be an E-LSA (or any other kind of LSA). I doubt it could be approved by a DAR for an E-AB airworthiness certificate, unless it was completely disassembled down to raw materials, rebuilt from the ground up, and a proper build log generated. But, if you're going to do all that, why not just start from scratch?
