My Sky Arrow ADSB solution
Part 1
For several years, I’ve been studiously avoiding any discussion of ADSB solutions. My plan was just to wait until December, 2019 and worry about it then. And I think it was a good plan.
But time sure flies! And here we are.
I decided on a Garmin GDL 82 with GPS, since I have no proper GPS source in the plane. $1,795 from Sporty’s. I went Garmin, since I’ve had excellent reliability and service from Garmin units over the years, and it will be interfacing with a Garmin GTX 327 transponder.
Anyway, got the unit about a week ago. Garmin certainly spared no expense on packaging:
(the blue USB cable is one I had lying around)
What’s in the bag:
No manual or templates. Pretty chintzy, if you ask me.
To be continued...
Re: My Sky Arrow ADSB solution
Part 2
I had room under the pilot’s seat, so that’s where it’s going.
I decided Velcro SuperLock tape would work, and added some aluminum stock to allow for more surface area:
Unit in place:
With seat in place:
I’ve ordered 3 coax cables. One to go from the unit to the existing transponder antenna, and 2 to splice together for the GPS antenna, so I can still easily remove my instrument panel, and I plan to mount the GPS antenna on my glare shield.
I have a friend with friends in an avionics shop who have the right crimping tool to wire the multi-pin connector. That may happen tomorrow.
I’m keeping the installation as simple as possible, so only 6 pins will be utilized:
Anyway, that’s where I am right now, and I’ll update as I progress. Open to any suggestions or advice.
Neat.
My unit has been 100 % reliable during last 14 or so months ... one thing you will need is a windows laptop running Garmin config utility to configure the unit.
Warmi wrote:Neat.
Thanks! The same friend referenced above has a Windows laptop (I don’t). He’s in the same process with a GDL 82 in his E-LSA Remos at our TN airstrip, so we’re learning from each other.
Has anyone found the “ground plane” for the GPS antenna necessary? I ask because GPS antennas seem to work just fine anywhere I’ve stuck them. The stock GPS antenna for my Cirrus’ #2 430 was just Velcro’d to the bottom of its glareshield from the factory with no ground plane apparent and worked just fine* and apparently passed FAA muster.
*If a Cirrus’ #2 GPS ever gets weak, the first thing to check has always been to see if the adhesive for the Velcro had succumbed to heat, time and gravity and was just dangling behind the panel. They used just regular hook-and-loop Velcro, which sure seemed chintzy to me.
Great solution Eddie, let us know if you encounter any issues with the setup.
I installed one on a CTSW, and used a ground plane. It wont be an issue for my Warrior installation. I know there are people flying around out there without a ground plane on the antenna, but my question would be does it meet the TSO-C154c requirements if the ground plane is not installed.
3Dreaming wrote:I installed one on a CTSW, and used a ground plane. It wont be an issue for my Warrior installation. I know there are people flying around out there without a ground plane on the antenna, but my question would be does it meet the TSO-C154c requirements if the ground plane is not installed.
I'm guessing that foil tape is cheap, so I may just stick some behind where its being mounted.
Silly question: does it need to be grounded, or is it just reflective in nature?
I think the foil tape without grounding will be fine.
Warmi wrote:Neat.
Same here, I've had mine for quite some time now and it's works great, never an issue with it. Paired to my Aera 660 and it's a great combo. Make sure to use RG-400 cable and not the cheap black stuff, RG-58 I think.
ShawnM wrote:Make sure to use RG-400 cable and not the cheap black stuff, RG-58 I think.
Yep, got the RG-400 stuff from WiFi Experts LLC, an eBay seller recommended to me by a fellow over on POA. I contacted them directly and got a discount for using PayPal. $40 all in for a 4’ and 2x3’ with a mix of straight and angled BNC and TNC connectors.
Remember that the instructions calls for a minimum cable length of 6.5 feet with 2 connectors for the GPS antenna to have the signal loss in the acceptable range. You may be okay with the additional connectors.
Thanks. I have a 3’ and a 4’ with a TNC joint in the middle to make the 6.5’ requirement while allowing me to disconnect at the joint to remove my panel.
Baby steps.
Antenna coax and 1/2 of the GPS coax installed just now:
Let me say that the coax fabricated by WiFi Experts LLC looks to be of very high quality.
The next and bigger step is pulling the panel to mount the GPS antenna, routing it’s cable and piggybacking onto the transponder breaker and finding a good ground.
To be continued...
I’m trying to wrap up the install today, but I just had a recurrence of Mature Onset Dyslexia...
I got the GPS antenna mounted to my glareshield, but it was sitting on my bench “backwards”. It wasn’t until I had all the holes drilled and the antenna mounted that I realized the antenna would end up facing the wrong way:
The aerodynamics isn’t a factor of course, but is the backwards mounting an issue otherwise? Rotating it 180° wouldn’t be a huge issue, but would mean relocating the connector hole and would leave two screw holes to be capped. It actually doesn’t look horrible as it is, kinda mimicking the lines of the nose.
Anyway, now just have to run power and ground and program, and I should be done.
proemer
Post by proemer »
Backwards mounting should be no problem.
I have a white antenna in a similar position... covered it with black tape... since I didn't like the white reflection in the canopy.
Pete
