Rotax 850 Etec
ScottyB
Rotax 850 Etec
Postby ScottyB » Sun Mar 18, 2018 6:33 pm
I'm looking at the rotax 850Etec, rated@165hp and only weighing 47kg... around 100 lbs before a gear box problem is rpm peek is 8000
But with an electronic rev limiter rpm can be harnessed to 6700 rpm(135hp) same rpm as 582 rotax (65hp)
Any thoughts?
Re: Rotax 850 Etec
Postby drseti » Sun Mar 18, 2018 8:13 pm
Since the 850 is a snowmobile engine, I doubt it has the redundancy one would want for aircraft use (two sparkplugs per cylinder, dual ignition, dual fuel pumps, etc.) I wonder if they can be converted to aviation requirements.?
