Added a new avionics toy to my panel
David
Postby David » Wed Aug 27, 2014 7:20 pm
I downloaded the Android app from the GRT (GRTAvionics, Inc) site and installed it on an old Android phone. Added the needed bluetooth to the GRT and paired them. It was very easy :)
The photo below is with the android app running on a Galaxy S4 via Bluetooth to the EFIS.
I modified the Otterbox Defender cover and holster. Ran a power usb plug from the Vertical Power. I cut the belt clip off and mounted it on the panel providing easy in and out of the holder.
David
EAA 1434 Belfast ME
