Survey on crosswind effects and accident experience.
eap1701
Post by eap1701 »
Hello everyone,
My name is Elliot, I am undergraduate student and student pilot, right now I am doing an independent research project on reducing the crosswind impact on an LSA/Ultralight tailfin upon landing by using something called a plasma actuator, to try and reintroduce stability and thwart accidents in the future. I wanted to get a perspective of the community on their experiences with crosswind landings and how they have dealt with them as well as hearing about your thoughts on transitioning between GA aircraft to light sports. The survey should only take 3 minutes to complete, thank you all for your time.
Elliot from Canada.
Survey: https://survey.sogosurvey.com/r/gudJ91
fatsportpilot
Re: Survey on crosswind effects and accident experience.
Post by fatsportpilot »
8. In your opinion, why do you think LSA craft are known for having high accident rates?
What? LSA accident rates are not high. At least not for any modern one with a 4 stroke engine.
Also reducing the effect of crosswind on light aircraft requires more than just reducing the effect on the tail. With light aircraft gusts and thermals can get under the wings and make things difficult. Unless your plasma actuators can block unexpected thermals and wind shear then they aren't a replacement for proper rudder control and stick into the wind.
