Having occasionally been guilty of posting a rant about disappointing aircraft parts and customer service culture (or lack of it) from makers (particularly about Rotax’s dismal customer-unfriendly policies) it seems only fair to offer positive feedback when it’s due.
Back in 2015 after our Rotax manufactured exhaust system on the RRotax 912 on our Skyranger ELSA broke we purchased one from CKT Engineering (https://www.cktengineering.com) in England. (They custom configure them for various different aircraft, as headers, etc., don't always run the same in different cowls, etc.) If I remember right, Paul at Flylight uses CKT's exhausts on Skyrangers.
We got the optional cabin heater shroud/system. A bit more costly than the Rotax... especially with the optional heater kit.
On the customer-service part of this story, we got a good taste in our mouth right off the bat: About the time we installed the new exhaust Rotax had slightly increased the length of their oil filters such that it became impossible to spin on the new filter without removing the exhaust header closest to it. This waspretty much a Rotax caused problem. Yet CKT re-fabricated a new header pipe for us with the slight extra clearance and didn't charge us for it or even shipping.
As for our experience with the exhaust itself: It is very noticeably quieter than the Rotax system it replaced. And though we can't objectively document this, it seems to give us a tad more power. The heater doesn't have much output...at least in our install...but keeps my toes from freezing and the cockpit about 10 degrees F higher than outside.
You only really find out what sort of company or service provider you're dealing with when there's a problem.
Well, months ago on our 912ul we detected very slight seepage of coolant right at one joint between the header and a rear exhaust manifold port on the header. (With hindsight it appears what happened is perhaps the joint where the exhaust header entered the muffler that joint froze {insufficient anti-seize?} allowing vibrations to go up to where the hard stainless steel header entered the head, and slowly gouged/shaved its way into the softer aluminum seat and put a pinhole into the water jacket.) It looked like this was going to be expensive and slow to remedy ... likely a rebuilt head. Worst case a new $3000 head from Rotax.
I contacted CKT with photos and description of the issue. .. at best hoping they'd supply a new header pipe as its top end was a bit worn.
An engineer there replied promptly. He said/recommended that we install a stainless steel sleeve in the exhaust port of the head.
After several emails and more photos revealing the pinhole they recommended we put a particular JB-Weld type epoxy under the sleeve when we seat it, and ,for good measure, use a high temp copper/silicone gasket compound between the header and and the sleeve. Held our hands all the way.
They assured us that they had personally actually used the Gorilla-Weld epoxy on other occasions similar with success.
They promptly shipped us a new header pipe and the sleeve at no charge. (Can you imagine Rotax doing that? Or even being able to talk to an engineer there?)
It was a pretty challenging job to get it all together (mainly because the rear facing exhaust port had little clearance and visibility between it and the firewall and we had to carefully lightly polish the head's exhaust port seat before seating the sleeve.)
Bottom line is the repair worked perfectly (as evaluated many hours later still), and it was CKT pulled our cookies out of the fire. Total cost to us basically one tube of Gorilla-Weld and one tube of high temp copper silicone sealer.... Under $25.
If that isn't enough to convince you CKT's support is off-the-charts, take a look at this reply I got when I posted the above praise in the rotax-owner.com forum:
"Me too! After hearing thru a third party that my tail pipe broke off at a weld at the slip joint where it attaches to the muffler CKT proactively reached out and I was sent a new tail pipe free of charge. Thank You CKT!"
Alex
In praise of CKT LSA exhausts AND their customer service
This message sent with 100% post-consumer recycled electrons
