Mark Gregor wrote:Nothing better than training in your own aircraft!
If your new to aviation its likely going to take time to figure out how you will use the airplane. Many beginning pilots start off thinking they will stay local but end up wanting an aircraft capable of going across the country. Give yourself a few flights to see if its for you and if you want to continue I'm of the thinking to buy the most aircraft that fits your budget. Its a lot less expensive to get the right airplane the first time.
I've been selling Tecnams for nearly ten years now and see a lot of buyers who pick an airplane on the internet. I think this is a mistake. Airplanes are very different in build quality and capability/flight characteristics and support. It is very different from buying a car where a Ford/Toyota/chev etc are all basically the same build quality and you can run down to your local dealer and get parts. Even in the last 10 years I have seen a lot of small companies come and go. Buying from a small company that goes out of business is going to make it difficult to find parts and resale will plummet. Some aircraft hold there value and some don't. There is a reason for that.
Airplanes are a big investment. I strongly suggest taking the time to travel around the country and get a good demo flight in several aircraft before you make a decision!
I find that very good advice.
