Feedback sought on Titan Tornado
Re: Feedback sought on Titan Tornado
Postby FastEddieB » Thu Oct 26, 2017 6:59 am
As an aside, the aircraft in question is a “Part 103 ultralight” with no N-Number.
It was suggested that as such it could not operate out of even a non-towered airport.
Anyone else heard of that? I know virtually nothing about these things.
Postby Merlinspop » Thu Oct 26, 2017 10:48 am
FastEddieB wrote:As an aside, the aircraft in question is a “Part 103 ultralight” with no N-Number.
§ 103.17 Operations in certain airspace.
No person may operate an ultralight vehicle within Class A, Class B, Class C, or Class D airspace or within the lateral boundaries of the surface area of Class E airspace designated for an airport unless that person has prior authorization from the ATC facility having jurisdiction over that airspace.
[Amdt. 103–17, 56 FR 65662, Dec. 17, 1991]
Found this on the EAA website for part 103 rules.
Postby FastEddieB » Thu Oct 26, 2017 11:07 am
Merlinspop wrote:“No person may operate an ultralight vehicle within...the lateral boundaries of the surface area of Class E airspace designated for an airport unless that person has prior authorization from the ATC facility having jurisdiction over that airspace.”
Trying to parse that.
Most nontowered airport’s surface area is Class G, with Class E starting at 700’. So yea or nay for such airport?
Its confusing to me the way it is written.
Postby 3Dreaming » Thu Oct 26, 2017 1:10 pm
Basically if the airport is in class G airspace you are OK. You can fly in class E airspace, except if the class E airspace goes all the way to the surface for a airport. If the class E airspace does go all the way to the surface, then you need ACT permission to operate within the foot print of that airspace all the way up to 17,999 MSL. In addition to that foot print of class E airspace for a airport you also need ATC permission to operate in class A,B,C, and D airspace, but I bet you knew that already.
Postby Merlinspop » Thu Oct 26, 2017 1:57 pm
[edit - the example below is incorrect. Time for me to review airspace depiction.]
So.... scrolling around VFRmap.com for an example, Vinton Co airport (22I), it is okay for a part 103 vehicle to operate out of, above and around, even in the overlying class E, but NOT within the conjoined circles surrounding nearby Ohio Univ airport (KUNI) and the O'Bleness heliport from the surface to 17,999 without permission from the controlling ATC. Correct interpretation?
Postby 3Dreaming » Thu Oct 26, 2017 2:28 pm
Merlinspop wrote:So.... scrolling around VFRmap.com for an example, Vinton Co airport (22I), it is okay for a part 103 vehicle to operate out of, above and around, even in the overlying class E, but NOT within the conjoined circles surrounding nearby Ohio Univ airport (KUNI) and the O'Bleness heliport from the surface to 17,999 without permission from the controlling ATC. Correct interpretation?
That is not correct. KUNI and the heliport are in class G airspace. The overlying class E starts at 700AGL.
An example from our neck of the woods would be KMVN. The dashed magenta line around the airport indicates that the class E goes all the way to the surface. When they say surface area they mean when that airspace actually touches the surface. For example the surface area for a class C airport is the inner most ring on the map. The outer ring indicates class C but has no surface area.
Postby Merlinspop » Thu Oct 26, 2017 3:39 pm
I stand corrected. The dashed magenta line fell completely out of my head. I left my post in place to preserve continuity but noted up front that it was incorrect.
Postby MrMorden » Sun Oct 29, 2017 11:02 am
If you are still talking about a Tornado, be very careful. While it’s technically possible for a Tornado to be part 103 compliant, my understanding is that it’s VERY difficult for one make the 254lb weight limit, and it’s also very easy for them to exceed speed limits. About the only wany to do it is to under-engine the airplane and then you can run into climb and acceleration deficiencies. And of course if it’s ever had the second sling seat installed it has to be an LSA.
I know of a couple of pilots locally that have flown “ultralight” Titans that were no such thing.
Postby 3Dreaming » Sun Oct 29, 2017 5:03 pm
MrMorden wrote: And of course if it’s ever had the second sling seat installed it has to be an LSA.
Do you have a source for this?
Postby MrMorden » Sun Oct 29, 2017 5:13 pm
There are no longer two seat “fat” ultralights. They all had to be converted to E-LSA or they became illegal, unregisterable airplanes after the amnesty deadline. I might be wrong, but I don’t think you can just pull out the second seat and make it legal.
Postby 3Dreaming » Sun Oct 29, 2017 6:19 pm
If you take a LSA out of LSA compliance there is not going back. I don't think the same is true with part 103 flying machines. without looking any regulations up, I think if it had 2 seats at one time and you can strip it down and meet the part 103 requirements I think you are good to go.
Postby MrMorden » Mon Oct 30, 2017 3:22 pm
3Dreaming wrote:
MrMorden wrote:If you take a LSA out of LSA compliance there is not going back. I don't think the same is true with part 103 flying machines. without looking any regulations up, I think if it had 2 seats at one time and you can strip it down and meet the part 103 requirements I think you are good to go.
After replying I thought about it some more, and I'm sure you are correct. Since it was never an "airplane" (by FAA definition, anyway) you can configure it any way you want. Even if you flew it with multiple seats, nobody would ever know unless there is a problem. Unless you go to register it or have an accident/incident, the FAA has no clue what the provenance of the airplane was.
The second seat is another one of those "not a problem until it is" areas of aviation for those that choose to break regs.
Postby 3Dreaming » Mon Oct 30, 2017 4:00 pm
The second seat is the telltale sign that it needs to be registered. A single seat even if it over weight or to fast doesn't garner as much scrutiny.
