jetcat3 wrote:Do y'all know how to downsize photos to be allowable to post on here? Thanks!
Drew
One way is to open the images in Apple Preview and choose "Export" from the File menu and choose jpg as the format. Then slide the image quality lever down to acceptable image size.
Thanks for all of the tips y'all. I tried Flickr but I'm not sure how to reduce the file size. Greg, I tried reducing the file sizes of a couple of different photos but the smallest I can get them down to is 491KB. Darn!
Joel, so exciting! Keep us all updated on your progress!
jetcat3 wrote:Thanks for all of the tips y'all. I tried Flickr but I'm not sure how to reduce the file size. Greg, I tried reducing the file sizes of a couple of different photos but the smallest I can get them down to is 491KB. Darn!
When you import into Flickr, there should be an option to set the file size. If you're using an iPhone, you can email the pic to yourself and you should be prompted to set the file size when you tap send.
Actually, you can import it at full size. When you grab the link it gives you choices of the resolution/size you want.
