Aerotrek opinions?
jjfjr
Aerotrek opinions?
Postby jjfjr » Fri Feb 19, 2016 3:42 pm
Hi;
I was wondering if anyone has experience with the Aerotrek A220 or A240 as an owner and/or pilot. They seem to be well built, have a good useful load and are at a reasonable price.
jjfjr
Re: Aerotrek opinions?
Postby MrMorden » Fri Feb 19, 2016 4:18 pm
jjfjr wrote:Hi;
jjfjr
If it were me I'd find a nice Avid Flyer, and get the same airplane and pocket the $80k difference.
Postby drseti » Sat Feb 20, 2016 12:29 am
All the Avid Flyers were licensed as E-AB. That means, unless you were the original builder and met the 51% rule, your annual inspection must be done by an A&P. One great advantage of building an ELSA version of the AeroTrek is that you can get a repairman certificate for it, by taking just 16 hours of training. And, an advantage of the SLSA version is that it can be used in flight instruction for hire. Otherwise, they are identical aircraft.
I maintain and occasionally fly an A220. Great flying aircraft, and easy to work on. If a taildragger made any business sense for my flight school, I'd probably have one on my flight line.
AvSport of Lock Haven
http://AvSport.org
Postby MrMorden » Sat Feb 20, 2016 5:02 pm
drseti wrote:All the Avid Flyers were licensed as E-AB. That means, unless you were the original builder and met the 51% rule, your annual inspection must be done by an A&P. One great advantage of building an ELSA version of the AeroTrek is that you can get a repairman certificate for it, by taking just 16 hours of training. And, an advantage of the SLSA version is that it can be used in flight instruction for hire. Otherwise, they are identical aircraft.
I don't disagree, but you can find a less than 51% completed Avid kit if the repairman certificate is important to you.
$80k will buy a lot of annuals.
Postby 3Dreaming » Sat Feb 20, 2016 11:06 pm
I'm sure you know this, but your wording was to clear. To apply for the repairman certificate you don't have to build 51% of the airplane. 51% of the airplane must be built for the purpose of education or recreation. To apply for the repairman certificate you must be the primary builder, but the FAA does not specify a required percentage.
zaitcev
Postby zaitcev » Sun Feb 21, 2016 8:13 pm
MrMorden wrote:If it were me I'd find a nice Avid Flyer, and get the same airplane and pocket the $80k difference.
Care to explain how you came up with this number? The sticker price of Aerotrek is close to $90k. That implies that your mythical Avid is only $10k. That sounds very far-fetched to me, unless we're taking a beater with Rotax 582 -- I was able to find one of those for $12k. There's no way, in my experience, to find an Avid with a 912, even an 80 hp one, for anything less than $25k.
Postby MrMorden » Mon Feb 22, 2016 8:30 am
My buddy bought a used Avid for $12.5k, it has been a great airplane. Yes, it has a 582 on it. Add $20k for a brand new 912ULS and you are still ahead by $57.5k. I'm assuing the $90k you quoted is base price, the one I saw at Oshkosh was over $100k.
My analysis stands, even if the numbers are slightly off it's not by enough to change the situation. Using your $25k number I'm off by $5k-$15k. If you buy a mostly built airplane not quite flying, I bet you could close that gap quickly. IMO the Aerotrek is significantly overpriced for what it is.
comperini
Postby comperini » Mon Feb 22, 2016 2:47 pm
I've owned one since 2007. I like it. Admittedly, my sticker price was a lot less than $80K they want now, but what other SLSAs are out there for roughly that same amount?
- Bob
COMM, CFI, DPE, Light Sport Repairman/Maintenance
Postby 3Dreaming » Mon Feb 22, 2016 6:49 pm
The ICP Savannah.
Postby MrMorden » Tue Feb 23, 2016 3:42 pm
comperini wrote:I've owned one since 2007. I like it. Admittedly, my sticker price was a lot less than $80K they want now, but what other SLSAs are out there for roughly that same amount?
Probably few or none. If you want a "factory" airplane and want it new, you are going to pay for that. I was just noting that the Avid is functionally identical for much less money, IF you are willing to accept words like "amateur built" and "experimental" when applied to your airplane. :)
Users browsing this forum: No registered users and 9 guests
