New to this...need help choosing an engine
Re: New to this...need help choosing an engine
Postby MrMorden » Tue Dec 08, 2015 10:16 am
Dnigolian wrote:
MrMorden wrote:
zaitcev wrote:If I wanted a 2-seat airplane, I would have to pay for Rotax or even a small ULpower (260i). I could consider AeroVee turbo if they ever put it on the market (after the death of Jeremy Monnett).
There are several Sonex flying with the Aerovee turbo. It can be bought here, cost is $10,999:
http://www.sonexaircraft.com/eshop/cart.php?target=category&category_id=329
Like it, but again may be more engine than I need. Just looking to be able to get off the water with 2 people. Beyond that I want fuel efficiency (for distance, not cost) and reliability. Guessing the turbo is less reliable than the non. I'll look into a "gently used" 912.
Honestly, I think that is your best bet. Water is draggy, and getting off with two people and less than 80hp would probably take more room than many lakes provide. A used 912ULS like the one I posted for $9500 is a better and more reliable engine at the same power as the turbo Aerovee is for $11k. BTW, there is no posted TBO for an Aerovee engine, but most require overhaul at 300-600 hours, vs the 912 TBO of 2000hrs. VW overhauls are much cheaper though.
Dnigolian
Postby Dnigolian » Tue Dec 08, 2015 4:09 pm
The 80hp 912UL has a DIY turbo kit that's an upgrade from the 914. Ends up with 5 more hp (120) and with a more reliable turbo. Nice option if I ever upgrade planes to a 4 seater Zenair or Bearcat which may end up taking the lead here thanks to FAA LSA limitations.
Postby SportPilot » Tue Dec 08, 2015 4:57 pm
Dnigolian
Postby Dnigolian » Wed Dec 09, 2015 5:00 am
SportPilot wrote:
Dnigolian wrote:The 80hp 912UL has a DIY turbo kit that's an upgrade from the 914. Ends up with 5 more hp (120) and with a more reliable turbo. Nice option if I ever upgrade planes to a 4 seater Zenair or Bearcat which may end up taking the lead here thanks to FAA LSA limitations.
It's not an LSA limitation. It's a Sport Pilot limitation.
Sorry...rookie mistake I'm sure.
JimC
Postby JimC » Thu Sep 01, 2016 6:43 pm
What does a 912 UL weigh with radiator and coolant?
Postby 3Dreaming » Thu Sep 01, 2016 8:26 pm
JimC wrote:What does a 912 UL weigh with radiator and coolant?
Installed weight is about 140 pounds. The installations I am familiar with use 3/4 gallon of coolant, so that would be 6-7 pounds.
Postby drseti » Fri Sep 02, 2016 4:25 pm
I concur with Tom's figure. The 912S series has the best power to weight ratio in its class. It is, however, a quirky engine that takes a little getting used to. After seven years, I can say I'm really enjoying the two I've owned, and have gotten used to the differences in a geared engine with a dry sump and cooled heads. But if you plan on owning a Rotax, I would encourage you to attend a Rotax Service Level course (and maybe buying Dean Vogel's DVD from Lockwood).
JimC
Postby JimC » Fri Sep 02, 2016 5:03 pm
So, about 133 pounds with radiator, oil cooler, and hoses, but no coolant?
Postby 3Dreaming » Fri Sep 02, 2016 6:42 pm
Users browsing this forum: Bing [Bot] and 4 guests
