Page 3 of 9
Re: E10 Unleaded Auto-Gas: My Big Mistake as LSA Owner!
Posted: Thu Apr 09, 2015 6:00 am
by Jack Tyler
"The only other thing I can think of is..."
Rich, one thing you haven't mentioned and may not have considered is that not every Sting is built out of the same drum of materials or in exactly the same manner by the same people. Who's to say a supplier didn't provide what was claimed to be a 'suitable substitute' at one time or another, or the builder shifted to a different supplier for pricing, availability or delivery reasons? Or perhaps the workers misjudged the ratios when mixing the materials for your tanks. It's unlikely every Sting is the mirror image of each of its kin.
I feel your California pain, being a CA native from back in the day when we had half the population and one of the best and most affordable public school systems - elementary through graduate degrees - in the nation. But things change, as should our expectations. Good luck with your research; you seem like the kind of guy who can 'get to the bottom of your tank' issue.
Posted: Thu Apr 09, 2015 9:00 am
SportPilot wrote:No, I will not. These aviation forums are aviation forums, not right-wing propaganda. I can give you several reasons I would like to leave the SE USA.
But what you do is take an aviation topic and STEER it to politics, by taking vocal offense to every offhand comment about anything related to government as part of the vast right-wing conspiracy. If you really want to keep things on topic, just let it go man.
Posted: Thu Apr 09, 2015 9:40 am
by drdehave
Good points, Jack (about potential resin variability). More reason to really take a close look at what the debris actually is.--R
(In addition, that "E10 is OK" language in the POH 1st appeared in 2009; my airplane was built in 2007. Did they change composites about that time?)
Posted: Thu Apr 09, 2015 10:03 am
by SportPilot
Posted: Thu Apr 09, 2015 11:49 am
by Wm.Ince
SportPilot wrote:MrMorden wrote:SportPilot wrote:No, I will not. These aviation forums are aviation forums, not right-wing propaganda. I can give you several reasons I would like to leave the SE USA.
No, that's not how it happens. There are a lot of right-wingers on these sites and few liberals. The right-wingers frequently take pot shots and when I respond, as the sole liberal willing to speak out, I get accused of taking topics political. I'm putting you on ignore. I suggest you do the same for me.
drdehave wrote:. . . "...living in the most regulated, government-oppressed state in the nation," . . .
Sporty,
Just out of curiosity, in the original post, by
drdehave, what did you find so "right wing?"
I thought the comments were pretty generalized in nature.
Posted: Thu Apr 09, 2015 12:21 pm
by SportPilot
Posted: Thu Apr 09, 2015 12:42 pm
by Wm.Ince
SportPilot wrote:"Ah, lots of more good questions and nice "bait" boys, but...living in the most regulated, government-oppressed state in the nation, I better not go further discussing them, you know? You better just imagine how that mini-fuel-tanker is being used."
This is "right-wing" speak. I wouldn't expect you to have a problem with it.
That sounds like a personal attack on me.
Do you really mean it that way?
Posted: Thu Apr 09, 2015 12:46 pm
by SportPilot
Posted: Thu Apr 09, 2015 10:33 pm
by bottleworks
(I'm gone. Everything deleted! Can't stand the ignorant data spread here).
Posted: Thu Apr 09, 2015 11:11 pm
by Nomore767
Rich,
Do you filter the pure.gas fuel when you refuel?
I've got a Mr.Funnel which I've used for this a few times, not every time I admit. So far I've not seen anything bad when I've taken samples from the gascolator.
Posted: Fri Apr 10, 2015 3:31 am
by BrianL99
MrMorden wrote:SportPilot wrote:Why do you feel compelled to follow behind me and comment on everything I say? I made a simple request. If you don't like what I have to say, why don't you just ignore it? Nobody was talking to you.
Not
everything you say. Just the 90% that is pure, belligerent trolling.
Why don't you just ignore the "right wing" comments? Nobody was talking to YOU, either.
Goose, meet gander.
We need a "Like" button for posts.
Posted: Fri Apr 10, 2015 7:10 am
by SportPilot
Posted: Fri Apr 10, 2015 9:47 am
by drdehave
The new fuel trailer has a commercial filter, so it's not coming in with the gas that way, i,e, w/ the new Pure-Gas.
Before, I have always used a Mr. Filter, when the E10 from local gas stations came in, in Jaz Jugs--all 5,000 gallons of it.
When I used to "sump" just a small quantity into one of those gas-tester-tubes, I often found a lot of beads and flakes getting to the gascolater--and almost clogging it completely!
That's when I started sumping mason-jar-fulls--to ensure getting all the flakes and beads out each morning--so they wouldn't ever make it to the gascolator.
Yes, pictures of the offending "stuff" are next on the agenda, if it keeps coming.
I still wonder about those Jaz Jugs--if they could be "melting," and thus the source. They do have some "acne" spots inside.
Anyway, yesterday I flew 3 hours on Pure-Gas, and it felt good!
PS/ I almost forgot: This afternoon, I am draining the tank and going in there for a look with a scope! I once had a boat that used to "puke" pieces of cloth from the bilge drain-hole. Then, when I finally had to replace the gas tank from E10 usage, I found the culprit: Somebody's shirt was laminated between the gas tank and hull! I likely won't find anything that gross, but it's worth a look, anyway.
(Thanks for the "Delete" button, Admin.)
Posted: Fri Apr 10, 2015 1:09 pm
by Jack Tyler
Rich:
"... that "E10 is OK" language in the POH 1st appeared in 2009; my airplane was built in 2007. Did they change composites about that time?"
You may have found your culprit, I'm sorry to say. It took a while for recreational groups like boaters and LSA owners to begin howling about the effects of ethanol in gasoline and much of the anguish - and manufacturers changing to materials and sealants more resistant to ethanol - surfaced during that 2-year period you mention. (The chronology is e.g. itemized here:
http://www.fuel-testers.com/ethanol_fuel_history.html)
I don't think I'd be as motivated to get pics of the particles as I would pictures of the tank interiors, well lighted. Usually not easy to do, I realize.
Posted: Fri Apr 10, 2015 1:15 pm
by SportPilot
