Garmin 696 Baud Rate
BrianL99
Postby BrianL99 » Sat Apr 04, 2015 5:24 pm
Who knows something about the 696 output?
I've had to mess with the settings on my TruTrak PFD and while I'm playing with settings, I want to make sure my Garmin and the TruTrak are properly set for communication.
This is what TruTrak told me:
Baud rate depends on the setting. NMEA In/NMEA Out needs 4800.
Aviation In/NMEA & VHF Out needs 9600.
Which means exactly nothing to me. Can anyone explain what that means?
Or tell me what the Garmin should be set at for "output" and how the TruTrak should be set for "incoming" ?
Thanks
Re: Garmin 696 Baud Rate
Postby MrMorden » Tue Jun 09, 2015 8:06 am
BrianL99 wrote:Who knows something about the 696 output?
Thanks
My 496 is connected to a TruTrak AP, I believe the data rate is set at 9600 on the Garmin. As long as you set the data rate on the TruTrak the same as the GPS, I'd think it would work.
