SLSA Dream Machine
Re: SLSA Dream Machine
Post by CTLSi »
MovingOn
Post by MovingOn »
CTLSi wrote:
Merlinspop wrote:
CTLSi wrote:.... already 2020 compliant.
Not with a 796 as the GPS source it's not. Just because it can provide data doesn't mean it's "2020 compliant".
The requirement calls for a WAAS GPS, the 796 meets that...
Pretty sure it does not.
Again, fall of 2019 sounds to me like a good time to start worrying about this sort of thing.
It's what I'm doing, anyway!
Post by Merlinspop »
The requirement does not specify WAAS.
Here's a briefing given by the FAA Surveillance Team Lead. Note slide 23. Does you Flight Manual contain the Language found on slide 18?
Dynon hinted that they are working on a truly compliant position source. Whether it is a box licensed from someone else or in-house doesn't really matter. They have a good rep for delivering what they say they will.
[edit: including the link would be helpful... https://www.aea.net/Training/courses/AD ... idance.pdf. ]
The way the rules are written right now, the GPS in the 796 will not meet ADS-B Out position source requirements. Of course, a lot can change over the next 5 years.
MovingOn wrote:
FastEddieB wrote:
drseti wrote:We get it. The CTLSi is your ultimate dream machine. We're happy for you.
And sometimes less is more.
Who needs more than 1 comm radio, mode C transponder, and an IPad or Android tablet?
Actually, I am OK with just a sectional. At least in my part of the country.
MovingOn
Post by MovingOn »
zaitcev
Post by zaitcev »
I never used E-6B after the checkride (not for pilotage anyway), but I use a clock in addition to the sectional.
MovingOn
Post by MovingOn »
snaproll
Post by snaproll »
I will worry about ADS-B out about 2019.. Already have ADS-B in... But have nothing compatible for ADS-B out. I began flying with a NARCO Mark 3, minimal instrumentation, a sectional, and a E-6B. Flying was enjoyable, spent more time looking out of the cockpit, and less time playing with the toys... Flew days, nights, long cross country's, and was never lost.
Gee, Don, when we started, the E6B was only an E6A. :wink:
drseti wrote:Gee, Don, when we started, the E6B was only an E6A. :wink:
Did you forget that you showed me your first flight computer?
Post by Nomore767 »
When I asked Vans about this same subject here is the answer:-
"The txp in your airplane is the Dynon SV-XPNDR=261 - that is not a module but the txp itself. We use this as it will be ADS-B compliant after 2020 (once a WAAS certified GPS source is available)".
So, I have ADSB-IN and the ADSB-OUT 'capability and function' now, it just won't be 100% compliant until there is an approved GPS source which Vans can then install to meet the 2020 goal. I think this is true with almost all other SLSAs on the market.
Merlinspop wrote: The requirement does not specify WAAS.
Correct, technically. However, the spec does require a "high precision GPS". Currently WAAS is the only way to meet that standard. A regular old GPS won't make that spec; even an original non-WAAS 430 is not compliant.
So unless somebody comes up with a new way to get the required precision out of the GPS system, compliance in reality DOES mean WAAS.
drseti wrote:The way the rules are written right now, the GPS in the 796 will not meet ADS-B Out position source requirements. Of course, a lot can change over the next 5 years.
Agreed. I'm hoping that at some point sanity will prevail and they will drop the certification requirement, then everybody with a Garmin 396 or better will have an appropriate GPS source, and we can move on to issues that might actually make a difference to flight safety. After all, the GPS satellite cloud really doesn't know whether your receiver has a TSO, the equivalent of the "Good Housekeeping Seal of Approval" (remember those? I'm really showing my age here...)
