Well, one thought was a Diamond DA20. Fairly economical, cruise is around 135 kts at 75% and 5.5 gph and 600 lbs of useful load. From my research, the only S-LSA that can truly run at 120 kts steady is the Arion Lightning and that's with the Jabiru engine. How many places can you take this bird to and have an A&P that's worked on them? Another somewhat negative forthe Lightning is the same with the Skycatcher and that's a fairly substantial empty weight. Not a whole lot of fudge factor if you want to take a passenger cross country with bags. Solo, the Lightning would be terrific.CTLSi wrote:What are you going to fly if you could get a PP? A Cessna 172? You will be spending double the money, flying at the same speeds, and having half the fun if you fly in a modern, sleek, low fuel burning, CTLS.
The ability to fly 400 miles at 120kts burning less than 10 gallons of auto gas at around $35 cost and getting there in less than 2.5 hrs can only be achieved in a CTLS or an LSA like it.
Get your SP and get going.
I'm doing the horse before the cart thing, but that's just me. I do this with anything I intend to endeavor. Don't take my thoughts the wrong way. If I can finally get my Sport certificate, there will be a smile the mortician won't get off when I assume room temperature, whenever that is.
One thing about S-LSAs, there's a lot of really nice choices out there. The only concern I can see is that there are so many, I question how all of them can survive. Tecnam is a big company that's been around a LONG time and will certainly be around. Flight Design is also doing quite well. Anyway, if the day comes, it's going to a great time for me.
David
