Thanks!Merlinspop wrote:As I said before, you are the only person who you need to please because you're looking for a personal use airplane, so as far as I'm concerned, wanting a specific color of stitching in the seats seam is perfectly legitimate (as an extreme example). I'm just offering up food for thought. Use your own salt.
Cable vs tubes. As noted, engineering tubes for control surfaces in a high wing is a feat. You asked why. Well, look at the path that has to be travelled. From a yoke, the motion starts behind the panel, then up a support structure to the wing, then out to the wing, then convert back and forth to up and down. There's a lot of turns and bends that have to be negotiated. Lots of fittings, joints and connectors (that can fail). Cable runs have to follow the same path, but can be made with a single cable, running through pulleys and fairleads (that can also fail, as can the swagged ends). If the designer wasn't scrimping to save grams of weight and spec'd an adequate cable size, and if the builder/designer rigged it correctly, you're not really going to tell a great deal of difference flying with SP privs. But, if that's a requirement for you, then it's a requirement.
Throttle... I prefer a levered throttle vs a knob to push or pull. But then again, with a knob on the panel, you can say "balls to the wall" every time you all full throttle. But no matter, I'm just happy when it gets louder and I go faster with added throttle.
Stick vs Yoke... Yokes make it easier to get in (you don't have to get your legs around a stick. Sticks really feel much more intuitive. Sticks can get in the way when you need to use that 'emergency empty gatorade bottle.' Just because that's all you know don't rule them out. They're the original "Joy Stick".
B
As I've stated in other posts, I am definitely not ruling out a stick, and who knows, I may find that I like them over the yokes? My former instructor once stated that "stick and rudder was real flying/more fun". Actually, I like the idea of the side mounted stick controls as seen in the Cirrus, FasteddieB's Sky Arrow and the Custom RV-10 AC model. (link below.) You will also notice that the Custom RV-10 AC in the video has the T-handle throttle quadrant.
http://youtu.be/gVuJ_s8Vqlc
As far as the T-handle throttle quadrant, again, I was always envious of the fellows that flew the Beech Skippers and Piper Cherokees, just found/find it to have a very nice sporty and modern look.
Please keep in mind that there is a Mrs. that also has a say in my situation.
Respectfully,
tl-3000.
