light sport IFR
Re: light sport IFR
Re: light sport IFR
Re: light sport IFR
OK, I concede that (A) is what makes it explicit, because "along an airway" puts you in controlled airspace.
Re: light sport IFR
Re: light sport IFR
True, but when most of us say "controlled airspace" we mean airspace with a specific controlling authority that we will probably have to talk to on the radio. A,B,C,D and the Mode-C veil of B (basically the spaces that will require ADS-B Out) is what most of us think of as "controlled".MovingOn wrote:All class E is controlled airspace.
It's not technically correct, but it's pretty common.
Re: light sport IFR
Re: light sport IFR
We need a new term for just the A,B,C,D, and Mode-C veil then...MovingOn wrote:Right, but it's probably best to use the correct terminology so as not to confuse. The FAR's are confusing enough already. For instance, you wouldn't want a new pilot to think 1 mile and clear of clouds is OK flying around in class E airspace.
"ATC airspace" ?
"ADS-B airspace" ?
"ABCD airspace" ?
"Radio airspace" ?
Re: light sport IFR
"DILLIGAF" airspace?
Re: light sport IFR
Re: light sport IFR
Right, but those spaces that will require ADS-B out are usually exactly the same as those we commonly refer to as "controlled".MovingOn wrote:Except A, B, C, D, E, and G airspace is all mutually exclusive (I think). ADS-B requirements are A and above, B and above, C and above, class B 30 nm veil and above ,and above 10,000 MSL. There is no exclusive ADS-B airspace.
Re: light sport IFR
Re: light sport IFR
Re: light sport IFR
Re: light sport IFR
"We" is the pilot community. We all understand (or should) than class E is controlled airspace. But we (meaning many pilots of all certification levels from student to ATP) also use term "controlled" to mean airspace where ATC direction is mandatory.MovingOn wrote:Who is "we." Controlled airspace is everything except G. I'm just suggesting that we ought to use the correct terminology.MrMorden wrote:Right, but those spaces that will require ADS-B out are usually exactly the same as those we commonly refer to as "controlled".MovingOn wrote:Except A, B, C, D, E, and G airspace is all mutually exclusive (I think). ADS-B requirements are A and above, B and above, C and above, class B 30 nm veil and above ,and above 10,000 MSL. There is no exclusive ADS-B airspace.
I don't disagree that we should use proper terminology, which is why I suggested we should apply a different term to mean airspace where ATC interaction is required. You didn't play along...so I guess we have to keep misusing the term and annoying you.
Re: light sport IFR
Yes, Eddie, as a matter of fact you do.FastEddieB wrote:"DILLIGAF" airspace?
