Page 13 of 16
Re: Affordable ADS-B out
Posted: Wed Dec 23, 2015 10:48 am
by dstclair
Expect a few much needed privacy updates over the next couple years for ADS-B out. From Avweb:
....The tentative solution, according to the Journal, is for the system to change its aircraft-specific identifying codes, perhaps daily or weekly, to prevent the public from identifying specific ADS-B transmissions as belonging to particular aircraft.
For the longer term, government and industry experts are studying ways to encrypt the data, to...
Posted: Wed Dec 23, 2015 10:57 am
by designrs
I've heard of some ADS-B units that offer the pilot the option to transmit an anonymous signal OUT or switch the ID is to active in a required area.
Posted: Wed Dec 23, 2015 11:01 am
by dstclair
The anonymous mode is allowable if the aircraft is squawking 1200 although support of this feature is not mandatory. Skyguard does not support it
Posted: Wed Dec 23, 2015 11:03 am
designrs wrote:I've heard of some ADS-B units that offer the pilot the option to transmit an anonymous signal OUT or switch the ID is to active in a required area.
There is an "anonymous" mode for ADS-B for aircraft squawking 1200. In the Garmin GDL-84 setup I'm considering, a toggle switch for anonymous mode is on installed in the panel. If I do that installation that sucker will be in anonymous mode about 90% of the time, since I rarely use flight following or otherwise talk to ATC.
Posted: Wed Dec 23, 2015 11:09 am
by designrs
dstclair wrote:The anonymous mode is allowable if the aircraft is squawking 1200 although support of this feature is not mandatory. Skyguard does not support it
SkyGuard allows setting the of the N number.
I wonder if there is a legal generic value setting that could be set like N00000?
Posted: Wed Dec 23, 2015 11:20 am
by dstclair
Obviously, one can set the N-number to whatever you want but that is certain to be a violation of some reg.
Posted: Wed Dec 23, 2015 1:26 pm
by SportPilot
Posted: Sat Dec 26, 2015 11:55 am
by designrs
Yet another example for the benefits of ADS-B In/Out traffic.
The other day I was flying at cruise in a busy costal area.
ADS-B indicated faster aircraft 8 o'clock 1,000 feet above and descending.
Then very quickly 700' above descending, direct course for me.
I turned to the right and descended.
Never saw him with my eyes ever... and especially would never have seen him at at 8 o'clock.
The situational awareness of ADS-B is awesome!
I will not fly without it.
Posted: Sat Dec 26, 2015 12:58 pm
Happy Boxing Day, everybody.
Now, did Santa bring anyone any ADS-B equipment?
Posted: Mon Dec 28, 2015 10:54 am
I agree it's very cool. But you will ground your airplane if the ADS-B setup fails?
Seems a bit...extreme.
Posted: Wed Dec 30, 2015 5:48 pm
by dstclair
drseti wrote:Happy Boxing Day, everybody.
Yes -- I upgraded my GDL-39 to a GDL-39 3D which adds attitude and pressure altitude (from inside the cabin) to my Garmin 795 (and Garmin Pilot App). This makes my 795 a fairly descent backup glass panel except it has ground speed vs. airspeed. I also like the Synthetic Vision display with true attitude. Aircraft Spruce has a "Trade Up" program and Garmin had a rebate so I got the unit for basically half price -- $450 net.
I have the GDL-39 and my Skyguard transmitter mounted in my closed baggage area which requires removing the seats and one of the ski tube storage units. Big PITA that takes a couple hours. I figured if I needed to do this to swap the 39's then I'd pull the Skyguard unit out to have it upgraded so it will wake up ground stations after the first of the year. Don offered to upgrade the firmware and GPS to make it compliant for $50. Would not be 2020 compliant but would put the upgrade off a few more years.
The FAA is upgrading the the ADS-B system to:
TIS-B/ADS-R Client Status logic will be modified to only provide TIS-B/ADS-R client status to aircraft broadcasting ADS-B with NACp>4, NACv>0, SDA>0, SIL>0, and NIC>4.
Skyguard and I were under the impression my unit would have SIL and SDA set to zero. I decided to check my specific output with the Garmin Pilot App (pretty neat little feature) and my salient values are:
NIC : 11 (< 7.5M), NACp : 10 (< 10M), NACv : 3 (< 1M/S), SDA : 1 (D), SIL : 3 (<= 0.0000001
Turns out my transmitter will continue to work without modification! This saves me disassembling and reassembling the interior twice! Pretty good Christmas present.
Posted: Wed Dec 30, 2015 6:32 pm
by SportPilot
Posted: Wed Mar 02, 2016 8:13 pm
by designrs
Apparently, even the military is having problems funding and may not make the 2020 mandate:
http://www.military.com/daily-news/2016 ... 700&rank=5
Posted: Wed Mar 02, 2016 8:37 pm
by SportPilot
Posted: Thu Dec 21, 2017 3:44 pm
by ShawnM
Reviving an old topic.....
Just ordered my Garmin GDL-82 and hope to have it next week to install in my SportCruiser (E-LSA). I also applied for the FAA rebate back in September so my $1795 purchase will become $1295 for an incredible ADS-B out option. It will interface with my GTX-327 and my Aera 660 perfectly. Coupled with my GDL-39 3D for ADS-B in, I have everything a growing boy needs now.
What are others using if not already equipped by the LSA manufacturer?
